Short ram intake, S70
Old Dec 13, 2009 | 01:25 PM
xxblindxx's Avatar
Default Short ram intake, S70
Hey I was thinking about putting a short ram intake on my car but wanted to ask some questions first..
After reading up a little bit I've knoticed that some people say you won't gain any performance from it but some say you get around 10 hp? Also some say it makes your throttle responce better? I've also read that if you don't have any other mods it won't do much of anything for you..?
Was going to get it from ipd or maybe est..
Just wanted to get some first hand experience?
Thanks in advance for the help
Old Dec 13, 2009 | 01:45 PM
S70driver's Avatar
1. You may or may not gain anything. You can possibly gain up to 10Hp. If you fo gain any, it wont be extremely noticeable.
2. You should see a little more throttle response. I did. I have the EuroSportTuning (EST)
3. Other mods will help out yes, but it doesn't neglect the part your wanting to install. Other performance parts will net you more possible power yes.
*Personally it's a noise maker. Sounds like Darth Vader, which is really cool.
Old Dec 13, 2009 | 02:03 PM
xxblindxx's Avatar
Haha thanks for the post!! Are there any downsides to it? It runs a little hotter air correct?
Old Dec 13, 2009 | 02:08 PM
S70driver's Avatar
The possibility of sucking in more hot air is present yes. That is why the OEM airbox is by far the best setup for our cars.
Old Dec 13, 2009 | 04:32 PM
ben watson's Avatar
Best thing to do is to get a K and N panel filter for around 40 pounds which replaces your standard one great investment it wont hurt anything! Trouble with forcing more air in is that most volvo engines reserculate engine fumes and forcing more air may put pressure on oil-seals thoughout the engine, crank seals , cam seals etc .
Old Dec 13, 2009 | 07:12 PM
xxblindxx's Avatar
I was reading up on "heat soak" seems like a major problem but how likely is it to occur?
Old Dec 13, 2009 | 07:42 PM
imhereftw's Avatar
Thumbs up
This is exactly what I did in my s80. Just getting a high flow drop in air filter will make a small difference, it will give your engine a little deeper of a tone with out having to go short ram and sucking hot air into your engine.
Old Dec 13, 2009 | 08:39 PM
xxblindxx's Avatar
thanks for all the input! now i just have to figure out what route i want to take =x
Old Dec 13, 2009 | 09:12 PM
Carrots's Avatar
If you go the short ram route, definitely use one of the kits like from IPD that includes a heat shield with a seal.
Old Dec 13, 2009 | 09:48 PM
gilber33's Avatar
Yeah, I was just going to say that, both SRIs have heat shields, but IPD's completely surrounds the filter. Intakes are always a good place to start when it comes to modding your car, but of course you should make sure everything else is up to par before you start modding.
Old Dec 13, 2009 | 11:10 PM
xxblindxx's Avatar
Yeah both IPD and EST have the heat shield, both are the same price so i was debating on which one to get, but the ipd one surronds more of the filter it looks like? Its hard to tell from the pics on the sites but ipd's does look like it surronds more area..
And the car runs really good, 115k on the clock (99 s70 t5)
dougherty93
May 15, 2013 11:25 PM
TacklaNHL
Aug 5, 2010 10:27 AM
98_S70_T5_Driver
Jul 1, 2009 06:35 PM
derekkoop
Apr 29, 2009 10:30 AM
pos960
Jan 20, 2007 04:03 AM
