Rough suspension
Old Nov 28, 2006 | 02:27 AM
850_Wagon's Avatar
Default Rough suspension
Hello -
I was thinking about changing the struts/shocks on my 850. The ride is a little too firm and makes for an uncomfortable ride. Any recommendations?
Old Nov 28, 2006 | 03:54 AM
JPN's Avatar
JPN
Default RE: Rough suspension
Greetings from Chicagoland.
Yes, 850s come with firm suspensions, as 850s are sport sedans/wagons.
If you wish to make the ride softer, then you can switch to softer struts/shocks. Whichever the damper you choose, make sure that they are of name brand and are preferably manufactured in USA, Canada, Germany, England, Spain or Japan (some other countries may also apply). Try not to go for cheapo, as they are sure to fail or will not give you what you expect.
I wish you luck in finding a good set of dampers.
JPN
Old Nov 28, 2006 | 04:53 AM
850_Wagon's Avatar
My wife usually drives the car and I took it to work tonight. I have a 70 mile commute each way. I kept thinking about how rough it is. We have used it on car trips too. I like the car a lot, but I wondered if that was the ride or just mine. This was the only 850 I drove or had ridden in.
Thanks for the info -
Old Nov 28, 2006 | 11:49 AM
Psaboic's Avatar
My son's 850 Turbo sedan has Monroe Sensa-tracs on it. The ride is not bad, a little rough, but that is mostly due to the bad roads and the fact that the car has 174K on it.
Just my .02 cents.
Good luck,
Glenn
spioana007
Mar 22, 2010 12:12 AM
1999 V70 GLT Benj
Mar 16, 2010 12:14 PM
knight rider
Suspension
Dec 23, 2004 04:47 PM
randyjoy
Nov 7, 2004 08:23 PM
M46Power
Oct 9, 2004 10:55 AM
