rusty metal rubbing noise coming from rear end
Old Jan 27, 2011 | 03:46 PM
boldtu's Avatar
Default rusty metal rubbing noise coming from rear end
My Volvo sounds like red fox's truck!
sounds like it is coming from the rear end when I go over bumps. I shook the exhaust system and did not hear anything. you guys have any ideas?
Thanks,
Chet
Old Jan 27, 2011 | 03:55 PM
vjaneczko's Avatar
Bounce up and down on the bumper - suspension maybe?
If not, check your e-brake pads. They may have fallen off their mounts and are bouncing around in the rotor.
Old Jan 27, 2011 | 05:04 PM
ibified's Avatar
that or possibly the rubber spring seat in the back is going bad. Are you sure its a rusty metal sound and not a non rusty metal sound? That makes a difference, you know...
Old Jan 27, 2011 | 05:28 PM
vjaneczko's Avatar
This is what you should NOT see when looking at the shock mounts:
http://www.youtube.com/watch?v=DOb58...er_profilepage
Old Jan 27, 2011 | 05:52 PM
ibified's Avatar
yeah thats pretty bad....
Old Jan 28, 2011 | 12:38 PM
boldtu's Avatar
I am replacing the shocks soon
I will take a look
Thanks,
Chet
Old Jan 31, 2011 | 12:57 AM
gdog's Avatar
Thanks,
Chet
Red Fox's truck; i like that... "What's wrong w/my truck dummy??"
Has anyone done any suspension or brake work to it recently? If so, ck for the brake backing plate bent into the disc/rotor; this will make exactly this kind of noise.
Old Jan 31, 2011 | 11:29 AM
boldtu's Avatar
I took a look at the left rear and it looks like the rubber stopper inside the spring has come loose. could this be the issue?
Thanks for all the ideas, as always you guys are a big help.
Chet
Old Feb 1, 2011 | 08:01 AM
vjaneczko's Avatar
IIRC, the rubber thingy in the spring is not of concern nor would it make any noise. I think you can just wedge it back up where it belongs and is just pressure-fitted.
I think you need to keep searching . . . . Have you inspected the delta links?
Old Feb 1, 2011 | 01:39 PM
ahirko's Avatar
What about a loose heat shield above the muffler?
Old Feb 1, 2011 | 02:52 PM
vjaneczko's Avatar
oooh, now why didn't I think of that! Yeah, check those, too.
Old Feb 1, 2011 | 10:56 PM
boldtu's Avatar
will do, I am taking a look tomorrow morning
I will let you know what I find.
Thanks,
Chet
rhys_d1983
Dec 7, 2011 11:09 AM
soukio
Nov 4, 2010 11:38 PM
gordon368
Sep 1, 2009 04:15 PM
Rascal2pt0
Dec 1, 2008 10:26 AM
beach4me
Apr 6, 2008 07:27 AM
