Seat Removal Procedure
Old Jun 1, 2010 | 01:16 PM
icebrick's Avatar
Default Seat Removal Procedure
I am going to use the seats from a dead 850 to upgrade my 240.
I will need to go to the wreckers with a few tools and little time to harvest them. (Yes I’m paying for them ).
Never having had an 850, how do you remove the front and rear seats.
Thanks
Old Jun 1, 2010 | 02:31 PM
vjaneczko's Avatar
I’m going to guess there’s a difference in the back seats between the sedan and the wagon – which do you have? Make sure you bring a can of PB Blaster for those bolts!
For the wagon, the front buckets are bolted on – not sure of the size, but I’d guess around 14mm. In my ’97, there’s a plastic cover that you have to wiggle off to expose the bolts. For the rear, and this is for my wagon, you tilt the seats forward, flip the red plastic handle down (located at the pivot hinge), then tilt the seat backward about 75% of the way and lift straight up. I’ve never undone the back rests, so I can only guess that there’s only a few bolts holding them in place at the bottom.
If you’re talking about a sedan, I would hazard a guess that the backrests are bolted to the frame and accessible from the trunk.
Old Jun 2, 2010 | 06:38 AM
icebrick's Avatar
Originally Posted by vjaneczko
I’m going to guess there’s a difference in the back seats between the sedan and the wagon – which do you have? ............
It's a sedan. The front seats are usually easy to figure out, but rear seats always seem to be a combination of lift, rotate, slide press or whatever .
Old Jun 2, 2010 | 06:44 AM
gilber33's Avatar
Each front seat is four bolts and usually a power/heat harness on the bottom. Also make sure to remove the seat control to expose the side impact airbag sensor and use the tool provided to block the sensor, it's hiding under neath the seat controls.
Bottom seats in the rear are just snapped into place. Grab the front of the seat and pull up. Bolsters are the same way, just yank them out. For the seat backs, tilt them forward, they pry out of their hing on the sides, once you get out of there they slide out of the middle "hinge".
Old Oct 18, 2013 | 06:48 PM
chax's Avatar
Default From another thread:
-Remove the seat bottom
-Fold down the seatback
-Pull it towards the side of the car and lift up on the outboard edge of the seat at the same time.
I haven't tried this yet, but it makes sense: I was diddling around with the clip, but I can understand how pulling the seat toward it could release whatever hold the clip has on the hinge.
UPDATE: couple things:
1) Before attempting to lift out either seatback, a clip has to be removed from the outboard bracket. It's necessary to access the bottom of the clip in order to remove it, so first tilt the seat bottom forward. There's a "tongue" on the bottom of the clip that prevents it from moving vertically: press in on this tongue while pulling up or prying up on the top of the clip, and slide it up and out.
2) It IS necessary to force the seat in the outboard direction, in order to lift it out of its outboard bracket: I use a 3-foot prybar, placed between the inboard mounting bracket and the seat, and voila! NOTE: the seat's outboard hingepiece is spring-loaded (to make it easier to return it to the vertical position, I believe [these seats are HEAVY!]): the closer the seatback is to vertical, the less rotational pressure there is on the hingepiece, meaning less pressure inhibiting removal.
Last edited by chax; Oct 22, 2013 at 08:35 PM. Reason: Important additional information
Old Oct 22, 2013 | 08:39 PM
chax's Avatar
Default Bolt sizes
All 8 bolts securing the front seats are 14mm. Pull the plastic bolt covers HORIZONTALLY, to remove. The bolts securing the rear seat belts are 17mm.
RobJamesInSheffield
2001-2013 model year V70
Apr 26, 2015 03:03 PM
fjkai
Jul 2, 2009 07:37 PM
garyraygray
Engine & Internal
Oct 28, 2008 03:42 PM
Cornfed
Apr 15, 2006 09:16 AM
pisque
Aug 3, 2005 03:14 AM
