Serpentine belt/pulley problem
Old Nov 1, 2010 | 03:18 PM
cjaama's Avatar
Default Serpentine belt/pulley problem
this summer i attempted to recharge the a/c (didn't take). the refrigerant was leaking out of the house while i was attempting to recharge the system. since then i've had a noises coming from the compressor like it was trying to work and now i have a high squeal coming from the belt or one of the pulleys. everything is still functioning fine, it's just making a squealing noise.
does anyone have any idea what might be causing the noise and if i should do anything about it? the belt looks like it's in good shape and i can't visibly see anything wrong with any of the pulleys or the tensioner.
Old Nov 1, 2010 | 09:48 PM
confused_al's Avatar
The only way you know for sure is to take the belt out, test each pulley by hand, PS and alternator's are usual suspects, but need get down there finding out.
grndslm
Mar 14, 2013 11:02 PM
Swedish Iron
Mar 29, 2012 08:44 PM
guest01
Nov 5, 2011 10:11 PM
dcm0123
Mar 13, 2010 08:12 PM
joshuastew
Aug 15, 2008 06:35 PM
