Serpentine Belt Question
Old Feb 29, 2008 | 06:49 AM
preese's Avatar
Default Serpentine Belt Question
Can the tentioner beadjusted to tighten belt?
Old Feb 29, 2008 | 07:05 AM
JimKW's Avatar
Default RE: Serpentine Belt Question
I don't think so, but not positive.
Old Feb 29, 2008 | 07:48 AM
JPN's Avatar
JPN
Negative; it is an automatic adjuster and if it's not putting out designed tension you need a new one. However, wait to hear from Moderator Tech. If Tech says you can, then, well, you can.
Have you inspected the belt surfaces for glazing? Let us know when you find the cause of the squealing.
JPN
Old Feb 29, 2008 | 08:29 AM
Psaboic's Avatar
Nope, it cannot be adjusted as far as I know
Old Feb 29, 2008 | 11:57 AM
JimKW's Avatar
They do make two different size belts though and they go on differently. Make sure you try to thread it on the right way for the belt you buy.
Old Feb 29, 2008 | 12:53 PM
jks2's Avatar
No the tensioner is made to keep the belt at a certain level of tension. It is not made to tighten up a loose belt.
Old Feb 29, 2008 | 05:43 PM
It is a spring loaded tensioner.
Old Mar 1, 2008 | 09:48 AM
Psaboic's Avatar
Good catch on the tip about the different size belts. I had forgotten about that one!
Old Mar 5, 2008 | 10:41 AM
preese's Avatar
It was the timing belt and water pump. The Serpentine belt was fine.
Old Mar 5, 2008 | 07:05 PM
JPN's Avatar
JPN
You caught it right before a catastrophe would have happened, good job.
JPN
Old Mar 5, 2008 | 11:37 PM
Volgrrr's Avatar
ORIGINAL: Psaboic
The shorter serpentine beltis for vehicles without A/C and the longer serpentine belt fitsvehicleswith A/C.
Old Mar 6, 2008 | 08:00 AM
JimKW's Avatar
ORIGINAL: Volgrrr
ORIGINAL: Psaboic
Not quite true. Yes w/o AC would be a shorter belt. But I have seen two different ways to route the belt both having A/C. I don't think the dealer even sells the short belt anymore, but if your car has the original belt the new one does not go on exactly the same as the one you take off.
Old Mar 6, 2008 | 08:09 AM
JPN's Avatar
JPN
Jim is correct, the serp belt length was revised so that there is more surface contact area for the alternator. The OEM Continental belt is definitely made better, as it has criss-cross patterns on the back of the belt for better grip, as compared to the aftermarket belts.
JPN
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
iscwebe
Feb 9, 2010 12:50 AM
rmmagow
Dec 20, 2008 08:53 PM
rationull
Aug 15, 2007 06:12 PM
toine910
May 14, 2004 08:57 PM
