Shifter release
Old Nov 22, 2006 | 03:24 PM
ENDEE666's Avatar
Default Shifter release
I have to use the override button to get out of park. Where is the sensor by the pedal located so i can either fix or replace it?
Old Nov 22, 2006 | 10:07 PM
JPN's Avatar
JPN
Default RE: Shifter release
http://www.volvospeed.com/Repair/Microswitch.htm
Cheers,
JPN
Old Nov 22, 2006 | 11:05 PM
MikeySq's Avatar
I had the same problem with my car, i just removed the solenoid coil because that is what was faulty and not the microswitch.
The only downside of removing the solenoid assembaly is that you can take the shifter out of park at any time even without a key in the ignition
-Mike
Old Nov 23, 2006 | 06:55 PM
ENDEE666's Avatar
MikeSq-
How dd you do that? Thats the solution I am loking for.
Old Nov 23, 2006 | 09:34 PM
MikeySq's Avatar
take the center console off so you have access to it and you'll see the solenoid coil there and just remove it and the little white gear thingy that it operates.... it's fairly simple... the hardest part it removing the console and there's instructions for that on a stickey thread in this(850) forum
-Mike
xDread92x
Jul 21, 2019 04:18 PM
jasond011
Sep 13, 2010 04:02 PM
sandraqu
Dec 24, 2009 02:36 PM
osbert
Mar 28, 2004 10:20 AM
colson
Jun 24, 2003 11:35 AM
