A shimmy when coming to stop
Old Jan 16, 2012 | 09:42 PM
TonyS's Avatar
Default A shimmy when coming to stop
I have an 1996 850 NA wagon with about 165K miles. Newer brakes and rotors all around, half-shims under the pads, newer inner and outer tie rods, newer struts and mounts. Recently I've noticed that when I pull up to a stop sign I get a slight shimmy — a vibration in the front end. If I shift to neutral before stopping it disappears. It's more in the annoyance category than a problem at the moment, but it has me wondering if this is the beginning of a transmission issue. Ideas?
Old Jan 16, 2012 | 09:51 PM
Do you have any vibration under acceleration?
Maybe you have an inner joint on one of your axles starting to go bad.
Old Jan 17, 2012 | 12:14 AM
You might also want to check the motor, transmission mounts.
Old Jan 18, 2012 | 10:15 PM
TonyS's Avatar
Thanks. I'll start with the mount theory. Now that I think of it, there's also a rattling sound at low speeds while accelerating, which I suppose could be the engine shaking around.
01S60
Mar 16, 2010 03:13 AM
2_Ton_Baby_Box
Aug 15, 2007 01:37 PM
zilinski6605
May 12, 2006 10:00 PM
Russen
Mar 31, 2006 09:50 PM
89740gle
Apr 21, 2005 04:37 PM
