shut off problems
Old Jun 15, 2009 | 10:58 AM
Arsenal6's Avatar
Default shut off problems
When I shut off the grumbles/vibrates shakes for about 3 seconds I am not sure why
my dad thought it was transmission fluid problem disappeared for a couple days now it back...
other people say it ABS telling me to take it apart and DIY...very tempted
I think it the ABS sensors on the wheels but I am not sure
it a 96 850 GLE
Has anyone experience this before? Please help
Old Jun 15, 2009 | 07:58 PM
Maybe fuel pump or relay?
Old Jun 15, 2009 | 09:48 PM
850tony's Avatar
seems as though alot of people these days are having issue with shutting their car off these days... weird.
Old Jun 17, 2009 | 03:08 AM
Arsenal6's Avatar
I am not sure...what other symptoms would there be? I see the engine oil light flash before it shuts down fully...I am not sure is it just those lights r last to turn off or nething...
I am told could be the alignment or tire pressure? Its not my car so I can't do nething just yet...
Old Jun 17, 2009 | 05:49 PM
meb7070's Avatar
Is it dieseling as as in it is still turning over when you turn it off?
that could mean you have a rich idle or a carbon build-up in the engine.
You can try some type of fuel system cleaner or sea-foam since i would think it to be a build-up since it just started happening.
Old Jun 17, 2009 | 10:12 PM
850tony's Avatar
try just normal cleaner before you try sea foam... sea foam is some really intense stuff and can open up seals and oil leaks that you never had before....
Old Aug 6, 2009 | 12:48 AM
Arsenal6's Avatar
normal cleaner...how would i use it? I have no experience in this and thanks for your reply even thou mine is extremely late
Old Aug 6, 2009 | 12:53 AM
VJZ's Avatar
VJZ
SeaFoam is intense stuff if you use it in the crank case. Fuel wise it burns like normal gas and generally doesn't effect seals.
Old Aug 6, 2009 | 12:56 AM
Arsenal6's Avatar
what brand is good for the 850? Do all brands work well?
Old Aug 21, 2009 | 05:31 PM
Arsenal6's Avatar
is there a specific brand?
jonqu
Sep 9, 2013 12:31 PM
nitrosport
Mar 12, 2013 06:44 AM
Pyrate
Jun 15, 2009 02:17 PM
DEH79
Apr 24, 2005 03:28 PM
01v70xc
Dec 16, 2004 10:11 PM
