Volvo 850 Suspension Sway
Old Aug 18, 2009 | 05:33 PM
frustrator-bolt's Avatar
Default Volvo 850 Suspension Sway
Just installed front suspension kit including new control arms / ball joints / struts / strut mounts / rebuilt rack & pinion / anti sway links / tie rod ends / rear struts & dampers . Also 4 new tires with alignment. Problem: Car feels like it is "surfing" at highway speeds 45 mph & above. Pitches & rolls out as well. The anti sway bar bushings look ok on visual but I did not replace.
Old Aug 18, 2009 | 07:35 PM
Tire pressures low?
Old Aug 20, 2009 | 08:37 AM
Default Rear Suspension Delta - End Links Volvo 850
I received a reply on another Volvo site and believe my issue is due to the fact that I replaced all the front suspension components but only the rear shocks / bumper stops. The trailing arm links are probably as worn out at 145,000 miles as the front suspension was causing an alignment issue and I am waiting on rear end link parts from FCP Groton so I can take back to the alignment shop after I replace the worn rear components.
Old Aug 20, 2009 | 09:02 AM
fcpgroton's Avatar
Former Sponsor
This sounds like a very good reason for your issue. I know I need to do the rear suspension on my volvo 850 also. Need to track down an oil leak first.
Old Aug 20, 2009 | 06:24 PM
Is your car a Wagon?
If so does it have a rear sway bar?
Old Aug 20, 2009 | 11:44 PM
No it is an 850 Turbo sedan
Old Aug 21, 2009 | 06:47 PM
Ok it is still kind of weird it sways so much.
But again I have not come across any of the rear bushings bad as of yet.
Sweet T5R
Mar 29, 2012 11:41 AM
autoxray
Oct 9, 2010 09:55 PM
Samhem
Suspension
Dec 20, 2006 01:17 PM
cronauerc
May 3, 2006 07:32 PM
lumanikus
Jul 26, 2005 08:36 PM
