small problem
Old Oct 18, 2011 | 06:37 AM
radio16's Avatar
Cool small problem
After installing fmic i have noticed cut out at 4500 rpm with 17lb boost . I replaced the cbv with another stock cbv even tho i didnt find any tears or holes in old one. Ive tested for vacuum and intake leaks in system, only to find nothing. Throttle body has been removed and cleaned. Im baginning to think i need to get an N.A. intake manifold and throttle body in order to get better airflow. I honestly am at wits end with it now. The other thing is just re ently (like 2 days) really rough idle right after cold start,especially when going into gear. I forgot to mention that ive cleaned ALL intake pipes and vac lines ,and the iac has been cleaned then reinstalled ,also put in new tps new wires rotor cap plugs (gapped first @.028 mm. Right now i cant think of anything else to do . Over the weekend i had both ecu and tcu disconnected to do cold reset . No codes were found before disconnect. ATthis point im at a loss for what to look at next. I still havent put white injectors in yet , i think ill hold off until i find out where i went wrong. I could use any advice that anyone wants to offer ,but make sure you see what ive already done so far.
Thanks
Richard
Old Oct 18, 2011 | 08:04 AM
boxpin's Avatar
radio16, can you describe the cut out a bit better?
Examples:
Revs to 4500 then wont go past that RPM
Hits 4500 and sputters
Hits 4500 then continues to climb but missing
Hits 4500 and boost drops
Old Oct 18, 2011 | 09:51 AM
MattyXXL's Avatar
You dont have a tune yet right?
I think your hitting fuel cutoff..
Old Oct 18, 2011 | 11:02 AM
boxpin's Avatar
Oh, if you don't have a tune that is definitely it. I assumed you did.
Old Oct 18, 2011 | 07:01 PM
radio16's Avatar
i thought fuel cut was 6000 rpm ?? eek if i added all this stuff that means i need more gas and its not getting it so fuel cut ensues??ohh dear-- has anyone heard of snabb/ ard - the do a range of ecu upgrades for the 850 and very reasonable priced can sum 1 check em out or give advice
Old Oct 18, 2011 | 07:45 PM
MattyXXL's Avatar
Stock Fuel cut off is 15PSI I believe, has nothing to do with RMP
Yes sir..... Both Boxpin and I have an ARD tune..
I got a white for now and I am extremely happy. I like It better than the IPD tune I had...
You can order them direct from Lucky here--->Active Research & Development
My advise pay the $50 for the core if you dont have a second ECu, you will get it back as soon as he gets your old one.
Vmaxx got a green tune... He Loves it....
If you mention that you are a member of FVC you will get 5% off
Old Oct 18, 2011 | 07:47 PM
MattyXXL's Avatar
BTW Box-
Did you ever get the boost issue figured out?
Is that how you ate up the trans?
Old Oct 18, 2011 | 10:08 PM
Vmax's Avatar
Radio get an ARD tune, you're hitting fuel cut, I seem to forget I have a tune at times, but when I step on it for passing, the pull is visceral!
Factory fuel cut is 6500rpms, after my tune, it is 6700rpms. Redline is 6000rpms.
I'm getting an IAC hose from snabb soon too and hope that cures why it doesn't hold 16 lbs steadily in the upper rpms.(boost leak?).
I messaged boxpin about that and his gearbox issue the other day.
What fluid do you use boxpin?
Old Oct 19, 2011 | 04:04 AM
Elchopperfreak's Avatar
Does a N/A throttle body makes the car faster?
Need to learn all this tuner lingo and letters.. Any other tricks?.
Thanks
Old Oct 19, 2011 | 01:03 PM
radio16's Avatar
Fuel cut occurs at 450--4700 when i hit the throttle hard.... engine will go dead for a split second ill let off th gas and then accel again without stmping it and itll be fine .... only happens when i try to gun it in sport mode ......i only think i can think of is fuel cut.....done all leak tests .....could it actually be my fuel pump going out
Old Oct 19, 2011 | 01:34 PM
MattyXXL's Avatar
Whats your PSI when it happens... anything over 14 or 15 will cause fuel cut off..
Old Oct 19, 2011 | 03:53 PM
It's kind of a hassle but one way to be sure would be to get a fuel pressure tester, attach it to the fuel rail and lead it out from under the hood and tape it down. Then go out and stick your foot in it and see if the pressure drops. If it cuts out and the pressure doesn't drop it's most likely the computer cutting injector pulse. If the gauge needle starts to wobble or drop it could be the pump having a hard time keeping up at higher demand or the pressure regulator acting up but more likely the pump.
You do have a clean fuel filter don't you ??
Are you running stock fuel pressure ?
Old Oct 19, 2011 | 10:12 PM
Vmax's Avatar
Check your camshaft position sensor too, make sure the connection is good and clean.
Old Oct 20, 2011 | 03:36 PM
radio16's Avatar
Ok boys and girls .... i think i figured it out... someone mentioned over boost... i toned it down to 14 psi and it stopped 4for now ..but now it feels like im driving an ice cream truck not a jet ..... im sad now
Does anyone have an 18 t that needs to be rebuilt in trade for a rebuilt and 10 000 mile 15 g ...... dont laugh ...its just a thought .... or does anyone have an 18 T they wanna sell for a reasonable price i dont care if i have to rebuild it thats easy.... im gonna go with the ARD GREEN and my white injectors i purloined at the junk yard
Old Oct 20, 2011 | 06:58 PM
Vmax's Avatar
LMFAO! I'm glad your rods have held up so well!
Old Mar 5, 2012 | 01:46 PM
radio16's Avatar
Default ard tune
got my new ARD TUNE finally.. went with the motronic 4.4 upgrade . Im now experiencing a low boost throughout the range of driving...it WONT go over 6# of boost ...the bcv is back in and the wastegate is set to stock ..ive tried everything i can think of ...aside from pouring gasoline all over the car and torching it ......once again i am at wits end ....ADVICE OR HELP WOULD BE APPRECIATED......thanks all
Old Mar 5, 2012 | 02:12 PM
  #17
Vmax's Avatar
lol @ torching, call Lucky and see what he has to say.
Old Mar 6, 2012 | 07:25 AM
  #18
radio16's Avatar
Default small problem
Problem solved...had my vacuum lines backwards ..2 words... HOLY F@#&...man does she step up now thanx al thanx VMAXX called Kristian got a lot of info ..great stuff glad i spent my paycheck on it ..worth every penny.
Old Mar 6, 2012 | 07:38 AM
  #19
boxpin's Avatar
Hehe, fun isnt it.
Old Mar 6, 2012 | 12:43 PM
  #20
Vmax's Avatar
now post up a vid of 40-100 pull please
