Smoking 850
Old Sep 2, 2010 | 07:04 PM
HellCreek's Avatar
Default Smoking 850
Hi,
I'm new to this forum. I own a 1996 850 Turbo. Today when I started it, I noticed a plume of smoke in the rear view mirror. It quit after a minute, but I decided to rev the motor to see if it would happen again, and it did. This is the first time that this has happened with this Volvo, and it wasn't smoking yesterday. It has around 125,000 miles on the odometer, and it has been serviced religiously. I have only used Mobil 1 at every oil change, and I use nothing but Volvo filters. The last oil change was about 500 miles ago.
Before this car, I had a 1990 740 Turbo. It started smoking, and the dealer replaced the turbo for $1200.00. I'm hoping that this is not the case with my 850. Could anything else cause this problem?
Thanks,
Tom
Old Sep 2, 2010 | 07:08 PM
RobTheModd's Avatar
Could be but there are other things that would cause it.
what color is the smoke?
and you say there is smoke upon start up??
go open your hood, and remove your dip stick, let me know if smoke is coming out of that... or even take a balloon and see if (air) is coming out of it.
Old Sep 3, 2010 | 10:41 AM
regime's Avatar
if its just smoke when you start it.. and assuming blueish smoke... its probably some oil getting by the valve seals...
Old Sep 3, 2010 | 12:00 PM
91shelby's Avatar
i personally dont think its your valves or turbo, those generally dont just start leaking overnight... i would say its most likely related to your PCV system, did you add any oil recently?
Old Sep 3, 2010 | 12:40 PM
HellCreek's Avatar
Hi, Guys,
Thanks for the ideas and suggestions.
The smoke is blueish, so it is oil and not antifreeze. Plus the engine oil is clear and not milky. I pulled the dip stick and started it, and no smoke came from there, and, strange as it sounds, only a little smoke came from the tail pipe this time -- not like the cloud that came out yesterday. (I noticed it in the rear view mirror yesterday. Today I had to look at the tail pipe.) I also could not feel any pressure at the dip stick tube with the engine running.
I changed the oil about 500 miles ago. I usually change it every 3000 miles with Mobil !, and it doesn't use any oil between changes. 125,000 miles on a Volvo engine is like the break-in period for most cars.
Old Sep 3, 2010 | 08:09 PM
RobTheModd's Avatar
True on the break in around 100k+ miles.
im running on 260k though. :P
ive got a nice smoke problem going on with mine, and it is my pcv, I just havent had the time to replace it lately.
Old Sep 4, 2010 | 10:53 AM
HellCreek's Avatar
I thought about cleaning the pcv system, but it looks like a major undertaking. What ever happened to the simple pcv valve in the valve cover that took 5 minutes to change?
Spike555
Aug 7, 2009 02:55 PM
oldervolvo
Apr 22, 2009 08:19 PM
andysvolvo
Jun 27, 2008 07:27 PM
andysvolvo
Jun 23, 2008 05:20 PM
danny
Sep 19, 2005 01:53 AM
