Smoking After Turbo Boost
Old Apr 10, 2023 | 10:14 PM
  #21
https://www.ipdusa.com/Articles/768/...%20gas%20pedal
I doubt you have a waste gate issue - that's there to cap the boost pressure when the turbo is fully spooled. A failed waste gate will either stay open and you don't get boost or stays closed and you'd over boost (and see the corresponding CEL...). However, there is also a diverter valve which releases the boost when you step off the gas (note some people mistakenly call this a blow off valve but there is a difference). Check out the link to the IPD article for an interesting read.
Old Aug 24, 2023 | 11:13 AM
  #22
MisterENB's Avatar
I posted the same thing on another thread. After driving for a while I went to add oil. Some came out of my oil fill port. I am guessing it is exhaust? And this is due to clogged PCV system and or ports in the oil pan? Can clogged ports in the oil pan cause this issue too. I plan to replace my oil pan sooner or later.
tylswil
Jan 14, 2019 08:25 AM
Mallen91
Jun 21, 2012 08:28 AM
SwedeInLA
Feb 2, 2012 07:15 AM
ram2500
May 23, 2010 08:19 AM
notny41
Nov 26, 2007 12:09 PM
