So I found an 850R
Old Feb 18, 2017 | 01:05 AM
firebirdparts's Avatar
Default So I found an 850R
Siting beside the road with a for sale on it. It appears it may be the real thing, but I did not know how to decode the VIN when I saw it. I don't want one, but I will probably need to buy it anyway. It is not with any collector; has quite a bit of body damage, but the alcantera interior looks good. Evidently it runs. I will keep y'all updated.
Old Feb 20, 2017 | 04:16 PM
Did you try the VIN decoder on the forum (up top - use the Tools pull down) - curious if that tells you anything? Also if you stop by again, can you see whether the ECU sticker shows a 628 (for the R) or 072 (standard Turbo)?
Old Feb 25, 2017 | 05:18 PM
Luke Woessner's Avatar
If you can look under the hood, the exhaust manifold on the R was different from the one from the standard T5. A google image search will show the differences.
850rt5
Dec 6, 2013 05:46 PM
AaronD81
Oct 28, 2005 11:25 AM
radthes
Sep 4, 2005 08:02 AM
Volvos since 1964
Feb 6, 2005 10:29 AM
M46Power
Nov 1, 2004 04:58 AM
