So I have coolant leaking from........
Old Jul 24, 2012 | 11:46 AM
Msuperbauer's Avatar
Default So I have coolant leaking from........
Where the two heater core hoses connect to the firewall in the engine bay? And I mean leaking like an open water faucet.... As of right now, no clleant in the car (drivers/passenger floor) how does this happen? Do I need new hoses? Are there new connections?? looking for tips and advice. Thank you in advance!
Old Jul 24, 2012 | 06:50 PM
MattyXXL's Avatar
Is it leaking from the hose or the coupler...
Either way if its the hose youll want to replace the coupler also cause it almost always breaks when you go to remove the old hoses..
Both hoses and the coupler should run you about $50..
You could try just replacing the o-rings if its the coupler thats leaking but like I said once you go to release the lines you almost always break the coupler.
ludeless
Mar 27, 2016 09:48 AM
pinhead
Nov 29, 2008 09:52 AM
Ishwar
May 1, 2008 05:44 PM
jonnyboyca
Feb 11, 2008 11:59 PM
Carbuff
Aug 16, 2005 11:19 PM
