Somethings wrong with the maf, help!
Old May 19, 2010 | 05:03 PM
nadz's Avatar
Exclamation Somethings wrong with the maf, help!
Hi everyone,
While driving home in my 95 850 today, I noticed the rpms were dropping, at an idle the car seemed like it was about to cut off. I checked the codes and from the A2 (Engine) it came up with 1-2-1 "Missing of faulty MAF signal" I don't know what to do? I remember about 8 months ago it was doing the same thing, but I took it to a shop and I think they cleaned the Idle Air Control Valve I believe. Please help
Thank You!
I recorded what the car is doing
http://www.youtube.com/watch?v=IVBU8HLCmwo
Old May 19, 2010 | 06:27 PM
JackDiesel's Avatar
Cleaning a Maf can help a little to keep it alive a little longer. Un plug it and see if the car runs any better. This will throw a CEL but it will also help to prove out that the maf is good or bad. If the car stays witth the dropping idle then its something else but if stays a constant rmp and seems better then its your maf going out.
Old May 19, 2010 | 06:58 PM
nadz's Avatar
I unplugged the connector to the maf, the only difference that I see is that (with the connector unplugged) when I push on the peddle to keep it at a steady 2000rpm it will stay at that for the most part. If I try to do it with the connector plugged in, the rpm will just drop and the car will almost cut off. But still in both cases with it plugged in or not the rpms still drop.
Old May 20, 2010 | 12:06 PM
nadz's Avatar
Here is a video of what my car is doing
Old May 20, 2010 | 02:43 PM
JackDiesel's Avatar
It could be a vacuum leak somewhere. How old are your spark plugs?
Old May 20, 2010 | 03:46 PM
nadz's Avatar
I never changed the spark plugs, I have had he car for 9 months. But could it be the maf sensor going bad since its throwing the check engine light?
Old May 20, 2010 | 11:42 PM
v4lve's Avatar
Pick up some maf cleaner from AutoZone or something as well as an Interference t25, take out the sensor carefully and give it a spray. Also heard of a hard ecu reset sometimes helping odd problems such as this.
Old May 21, 2010 | 11:37 AM
JackDiesel's Avatar
Disconnect the battery cables(both) and then hold the + and - together for about 20 seconds it will pull all of the power out of the harness. Look for some vacuum leaks and how did you clean your ISV? Did you soak it in a bag of carb clean or just spray it out?
Old May 22, 2010 | 09:30 AM
nadz's Avatar
I cleaned the Idle Air Control Valve by spraying the holes with carb cleaner. I also cleaned the mass air flow sensor, when I started the car for the first 30seconds the check engine light was off but then it came back, with the 1-2-1.
goodboyz358
Dec 7, 2010 01:40 PM
goodboyz358
Dec 5, 2010 09:40 PM
drswansea
Feb 15, 2010 10:39 PM
qstyle
Feb 17, 2009 11:57 PM
J Telectro
Jan 10, 2007 09:25 AM
