A/C Compressor not kicking on
Old May 21, 2010 | 12:00 AM
91shelby's Avatar
Default A/C Compressor not kicking on
I just recharged my system today, but my compressor still wont kick on fuse is good, what should i look for?
Old May 21, 2010 | 08:32 PM
Do you have power at the low pressure switch?
Old May 21, 2010 | 11:36 PM
91shelby's Avatar
will check tomorrow
Old May 22, 2010 | 09:52 PM
Are you sure you have enough freon in it?
Old May 22, 2010 | 10:03 PM
Chebucto's Avatar
Time to pull the clutch and remove one of the washers....ask tech....he has the walkthru.
Old May 22, 2010 | 10:06 PM
That information is in the sticky.
Old May 22, 2010 | 10:09 PM
IhateVampires's Avatar
My a/c clutch cycles off and on every couple minutes for some reason, but my a/c actually works still.
Old May 22, 2010 | 10:12 PM
Default Compressor kicks on and off
Probably a little low on freon. If it's not low, the clutch is likely going bad.
Nick850
Dec 8, 2011 06:52 AM
KeithS60&V70T5
Aug 10, 2010 04:36 PM
bumere46
Jun 27, 2009 06:42 PM
jonsey1
Aug 8, 2008 06:59 PM
grangel
Nov 21, 2007 06:06 AM
