Spark Plug Cover help?
Shouldnt burn. However, it may discolor over time, at which point it will look like crap. Also, you're not gonna be able to get it to lay flat over the "volvo" or "20 valve" that's stamped into it.
if you want it to look right, get this: http://www.vivaperformance.com/produ...B47%7DC70.html
just be sure you clean the bejeezus out of it before you paint it. I soaked mine in purple power for a while, then scrubbed it, then soaked it some more. Then I rinsed it off really well in water and then wiped it down with rubbing alcohol before priming and painting. Also, be sure to use high temp paint. If you have any questions on the process, let me know.
