Speed Sensor Problem 1995 with a 1996 trans
Well did a Engine and Trans Swap
while Installing New trans i did not notice the
the Trans are different between years
I got a 1995 Volvo 850
But the trans is From a 1996 And Newer
i have tryed to wire it up to a 1996 and new
changed the connection, but that did not work
Changed computers (4.3, 5.3, 7.3, Trans Computer Numbers)that did not work either
rewired to the Front Driver Side ABS sensor Kind of Worked but it did not shift
Had Different Codes With Different computers
5.3 ECU - I get Shift Solenoid B malfunction
7.3 ECU - I get Speed Sensor Malfunction
7.3 ECU Different - throttle Position Sensor and Speed sensor Malfunction
I searched but could not find his problem or how to fix it been working on it for 4 weeks trying to fix this problem
But is there a way to wire the the speedo to work, so it can shift?
Is the million dollar question here
bluesb4sunrise
07-18-2012 12:57 PM
Eric's Hot Rod Shop
07-14-2011 08:26 AM
urbs4
10-31-2009 12:02 AM
