Speedometer works sometimes while the yellow arrow flashes
Old Feb 25, 2016 | 07:50 AM
Radfordalum's Avatar
Default Speedometer works sometimes while the yellow arrow flashes
My 95 850 turbo has been acting up. The speedometer works periodically and the yellow low gear arrow flashes
Old Feb 25, 2016 | 08:02 AM
tryingbe's Avatar
You got a transmission problem. Get the codes read.
http://www.matthewsvolvosite.com/read-codes-volvo-850
Old Feb 25, 2016 | 11:05 AM
could be the ABS module, or the speed sensor. The flashing arrow is saying there are codes to be read. Try tapping into the A1 port on the diagnostics module, press the button for 1 sec, read codes, report back :-)
Old Feb 27, 2016 | 09:09 PM
Psaboic's Avatar
Ours was and still does that if it sits for a few days and the battery gets a little low. The yellow arrow is flashing because the transmission is not getting the speed sensor signal from the speedometer, which is electronic and is not working correctly due to low voltage.
On ours, the speedo will not work for about the first three miles then will start working. However the yellow arrow will keep flashing until you shut it off for a couple minutes and re-start it, then all is well. (or as well as can be expected for a 21 year old car with 265,000 miles)
Radfordalum
Jun 12, 2015 07:23 PM
hunterw0026
Mar 21, 2011 09:49 AM
850R Dave
Dec 16, 2009 09:41 AM
thewolf
Mar 24, 2009 03:07 PM
