stalling after 20 sec.
Old Jan 9, 2007 | 03:52 PM
chriswhalen's Avatar
Default stalling after 20 sec.
Iam working on an 96 850 non turboproblem is that the vehicle will stall out after 20 sec. on running I have noticed before vehicle starts to run rough and stall out that the spark drops off all cyl. I have replacedthe cam sensor, the crank sensor (pulse sensor). The previous garage has replaced cap, rotor, plugs,wires,ect sensor. I have also tried a known good coil. they are no codes in this vehicle.any help in this matter would be greatly appreciated[:-]
Old Jan 9, 2007 | 04:02 PM
Default RE: stalling after 20 sec.
I failed to mention that the timing is on the mark and when the spark is lost I can give full throttle and I can regain spark for another 20 sec.Also after vehicle dies vehicle will restart with out a problem for 20 sec.and then die out again..[:@][][&o]
Old Jan 9, 2007 | 07:51 PM
axelm's Avatar
Have you checked the idle air control valve?
Old Jan 9, 2007 | 09:30 PM
check the Cam position sensor plug for good connection.
volvoinct
Jun 8, 2022 03:30 PM
rhk
Jun 25, 2011 07:12 PM
infowire
Mar 13, 2010 06:58 PM
Bazillio
Nov 18, 2009 07:24 PM
GaryBrad
Feb 8, 2007 10:39 PM
