97' N/A 850 losing a lot of oil
Old Jan 7, 2007 | 10:45 PM
850_Wagon's Avatar
Default 97' N/A 850 losing a lot of oil
Hello -
My wife came home on Friday night and told me the car was smoking. I went outside and found that oil appears to be leaking near the back of the motor on the driver's side. I am really not sure what it is. I took a few pics, but it says my file is too large.
There is a stainless line in the area. Any thoughts or help would be great. It does not leak when the car is off, only under pressure.
Old Jan 8, 2007 | 03:04 AM
850_Wagon's Avatar
Default RE: 97' N/A 850 losing a lot of oil
I know I did not post too much info, but a little direction would be great.
Old Jan 8, 2007 | 03:38 AM
JPN's Avatar
JPN
Hello Mr. 850_Wagon,
Greetings from Chicagoland.
If the 850 is N/A, then it is not the turbo oil return line. I wonder what else was there.
Did you see the colour of smoke, or smelled it? Is it really the engine oil that is leaking? It could be transmission fluid, coolant, etc... But if it's the engine oil, there may be a failing O-ring or seals in oil lines, but at the moment I cannot recall oil lines in the back of the engine on driver's side, except for turbo models.
If you can somehow upload the pics, that would be the best. What format are the pics using? Usually jpegformat requiresless bytes.
Best wishes,
JPN
Old Jan 8, 2007 | 03:48 AM
850_Wagon's Avatar
Hi JPN -
How's Chicago? I was there in January a few years ago on business. I came in a snowstorm and left in the snowstorm...
I can give you 2 definites. It is not a turbo and it is definitely engine oil. I checked the dipstick as well and was low. I added more since. I asked my friend who is a Chevy guy, but not much into the Volvos and did not know what area that was either. He was thinking something like it was a main oil line to the engine?? What is in the area.
The pics are JPGs and came off my camera with 946kb in size. I took a screenshot of the picture and seemed to work.
Thanks for your response.
[IMG]local://upfiles/7922/25F5A8AA6F9A44CD864DAC8646A3A591.jpg[/IMG]
Old Jan 8, 2007 | 08:49 PM
That is your rear Cam seal.
Since it is a Non-turbo car make sure the Flame trap isn't clogged.
Also look under the cap and see if it is leaking there as well.
Old Jan 8, 2007 | 11:18 PM
850_Wagon's Avatar
Hey Tech -
I am not familiar with a flame trap. Can you give me a little info on that? How to check it out? What to look for?
Thanks!!!
Old Jan 8, 2007 | 11:59 PM
The flame trap is in the unduction hose just before the throttle body. There is a black housing that holds the flame trap. It has 2 hoses going to it.
1st make sure the hoses aren't clogged mainly the small one.
Next remove the housing and make sure the insert isn't clogged.
Old Jan 9, 2007 | 12:26 AM
850_Wagon's Avatar
Does not sound to difficult, I will check it out and let you know. Thanks Tech.
Old Jan 9, 2007 | 10:49 PM
850_Wagon's Avatar
Ok - I took a quick look before where is the flame trap in the picture and if I take it apart will oil come out? It might sound stupid, but I would rather ask then screw it up.
Old Jan 10, 2007 | 03:56 AM
info2x's Avatar
That's a smart mindset, even simple jobs can become major ones if something doesn't go wrong (I'm the king!). Here are some flame trap pics
[align=left] [/align]
Old Jan 10, 2007 | 05:35 AM
850_Wagon's Avatar
Wow - that will help. Thanks for the link. It will take me a day or two to get back to the car, but when I work on it, I will post my results. Thanks!!
guest01
Sep 8, 2013 01:10 PM
92_240_sedan
Jul 6, 2013 10:17 AM
jessicat
Mar 8, 2010 11:19 PM
jfarsetta
Mar 4, 2008 08:15 PM
