Stalling issues/Midas just replaced fuel pump two weeks ago
Old Sep 18, 2014 | 06:56 PM
Pinenvy's Avatar
Default Stalling issues/Midas just replaced fuel pump two weeks ago
Hi,
I just joined the site because I'm having some issues with my 1993 volvo 850 glt. It had stalled and failed to not restart a couple weeks ago so I had it towed to Sears. Sears determined that the fuel pump was the problem and it needed to be replaced and they didn't have the tools to do the job so I would have to take it to a volvo dealership. I ended up calling around to see if there was a place that would do it cheaper then volvo. I settled on Midas. They supposedly put a refurbished fuel pump in and it ran decent after that. Now I'm having stalling issues again and it's not starting the first couple tries. It feels like heat is coming from the engine to the inside if the car by the steering wheel while I'm driving. It felt like heat was coming from engine inside by steering wheel before the fuel pump was replaced. I took the car back to Midas today and they said that the fuel pump relay needs to be replaced. The guy hand me the relay and told me that it's not supposed to hot the way it is. The relay felt felt pretty warm , "hot" is kind of stretching it a bit at the time. He also said that there is a fuel injection knocking going on as well. He said $170.00 total to replace the relay and hope that fixes the problem. So I started googling the fuel relay and i discovered that it's a $56.00 fuse that I can replace myself so auto zone ordered it and I will put it in tomorrow. But how do I know that Midas is being honest with me? They told me 170 for the repair which is basically robbing me! So now I'm Leary that the relay is actually the problem and I'm wondering if they did in fact really replace the fuel pump. Also I am constantly refilling the antifreeze. I can't believe how fast this car is going through antifreeze! And there STILL feels like there is heat coming from the engine into the car by the steering wheel as I'm driving. Also my drivers seat feels like it's heating up ever since the fuel pump was replaced. The seat never got warm/hot before the pump was replaced. Any help/suggestions/views/opinion/thoughts/insight ect is welcome and very much appreciated! Thanks for reading my very lengthy post lol
Sherry
Old Sep 18, 2014 | 10:30 PM
damien360's Avatar
Fuel pump relay is a very common cause of the stalling.
Old Sep 18, 2014 | 11:43 PM
Phil 850's Avatar
I think you have a 21 year old car and like the rest of us you need to pick up a manual and at least go through the codes so you go to a shop with a little knowledge. I had to replace the relay on mine and then I had to replace the fuel pump because both had issues.
Old Sep 19, 2014 | 05:17 PM
difflock54's Avatar
Re: The coolant loss. Check your heater core for a possible leak or the flow/return hoses to it going thru the firewall. Your carpets may feel a bit wet too if it is the heater that is accounting for your coolant fluid losses.
Old Sep 19, 2014 | 06:47 PM
Welcome to the forum
If you do a search here and or Google you will see the fuel pump relay pop us as a very common culprit for stalling, intermittent hard or no start.
You can try to find another in a salvage yard but it might not have (any) much more life than yours, you can fix it yourself or just break down and get a new one.
How to repair: http://www.matthewsvolvosite.com/for...ic.php?p=32573
Volvo 850 Parts | FCP Euro
Product Search: "fuel pump relay"
There is a difference in the turbo and non-turbo fuel pump relays if you go salvage yard shopping
Attached Thumbnails Stalling issues/Midas just replaced fuel pump two weeks ago-fuel-pump-relay-2.jpg
1995Volvo850
Jun 27, 2012 10:27 AM
jbuck
Nov 16, 2011 05:48 PM
kjohnson
Oct 2, 2008 10:56 PM
casique
Mar 2, 2007 08:23 PM
