Start OK but everything eles are won’t work
I have a 97 850 GLT wagon, It starts OK but once in a while I cannot shift to Drive. I alsonoticed that when this problem occurrs,everything electric also does not work, such asthe side mirror motor, headlights etc. I have to turn off the carand then start itagain, sometimes more thanonce,inorder for theproblem todisappear. Iwas looking at theHaynes repair manual electrical wiring diagram to understand it butit is not clear to me especially on ”3/1”after key position and termial.Does this indicatea relay number 3? and whereis thelocation for terminal and relay for these?
Id really appreciate your help and comments
Chuck
Chuck
RE: Start OK but everything eles are won’t work
Sounds like you need to replace the electrical portion of the ignition switch.
http://volvospeed.com/Repair/ignit_switch.php
RE: Start OK but everything else are won’t work
And if that doesn't solve the problem, you may also have to replace the PNP switch (though I too assume the ignition switch may be starting to go):
http://www.fcpgroton.com/volvo850other.htm
Ignition switch: US$51
PNP switch: $110 for genuine Volvo, $80 for Scan-tech (if it were my car, I would go with genuine Volvo).
I hope this gives you some hints.
JPN
JPN
Ethan Morrisson
Engine & Internal
12-21-2012 04:31 AM
