Starter and AC Question
My mom is having a couple of issues with her 1997 850 N/A. The first is when she starts the car it makes a god awful squeeling, but it stops as soon as the motor starts. I told this to a friend who owns a shop and he said the starter could be going bad. Does sound like a correct diagnosis, and how would I be able to test the starter? I did some searching and found that the starter is in the front and easily replaced, but where is it exactly? A couple of the picture links in other threads did not work.
The second is when she turned on her AC when I was under the hood, the compressor would tun on, then turn right off, and repeat. I'm guessing that the AC needs to be recharged. I was looking at the recharge kits you can buy with the leak sealer, but if the 134a is leaking out of a seal that isn't going to help for very long, so I was wondering what in the AC system has a tendency to leak first.
The second (and probable) situation is that it is low on 134a. There are two main failure points in the 850's a/c system. One is the receiver/dryer aka accumulator, which hangs down behind the radiator on the passenger side. It looks like a 12" long cylinder situated vertically. Mine rusted out the bottom, it will be obvious if it has failed. It is easy to replace, and the part is around $100 or so.
The second (and most time consuming) is the evaporator inside the dash. There really is no way to tell if it has failed outside of trouble shooting everything else. There is an excellent writeup to repair the evap however plan to take a weekend to do it. The part is around $150.
I simply recharged my system every year with 134a. It seemed to last 4 months or so per charge, however now it is down to about 3-4 weeks. I will be replacing my evaporator this spring.
The starter is below the intake manifold where the engine and transmission mate up together. I was able to get it out by removing the airbox, the intake hose, and loosening the transmission dipstick. It will come out easier if you also remove the fan but I was able to snake it around things without doing so.
...Lee
...Lee
The solenoid on the starter should extend the pinion gear once powered. If the solenoid is faulty, the engine wouldn't start because the pinion gear is not engaging with the ring gear on the flywheel.
I would also check the serpentine accessory drive belt for signs of glazing.
Wait for others' replies as well.
JPN
JPN
If the car starts when you crank, then solenoid is not a problem but the starter motor must be making noise from aging and running dry which means that its time to replace it.
For airconditioning, If compressor is engaging and disengaging, then its not a major leak at all and you will be good by just refilling it.
