Starter Relay
Old Jul 23, 2010 | 07:51 PM
toddmr's Avatar
Default Starter Relay
My 855 won't start.
Put in the key and turn and it doesn't crank.
Christmas tree on the dashboard.
Fuel pump active.
Sometimes I'll get a click like a relay and sometimes not.
I've seen a number of references to a "starter relay" but no instructions on where it is.
Help?!
Old Jul 24, 2010 | 12:35 AM
Ozark Lee's Avatar
Beyond the solenoid on the starter itself there is no starter relay. The only thing between the ignition switch and the starter is the PNP switch if you have an automatic transmission.
Try starting it in neutral and see what happens.
...Lee
Old Jul 24, 2010 | 02:51 PM
mudpie's Avatar
Short answer...probably a dead starter.
Get a piece of wood, like a 2x2, a couple feet long, and stick one end down against the starter and tap on it lightly while someone turns the key. You might get it to engage, but it probably won't crank very well. If so, it's dead.
Old Jul 25, 2010 | 11:49 AM
fcpgroton's Avatar
Former Sponsor
Give the shifter a good rowing through the gears to see if that helps. If not, then try the "bang the starter" fix and see if that helps. Let us know how you make out.
sleech
Jan 25, 2020 05:07 PM
dsteele485
Aug 28, 2012 08:11 AM
davidsr
Jun 17, 2011 04:34 PM
EEaudio08
Aug 17, 2010 11:21 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
