Starting Issues
Old May 21, 2013 | 06:30 AM
  #21
If the motor was cranking, the starter was fine.
As for the cover on top of the motor, you should have tools for that in your tire change kit pouch.
For under $50 you can purchase the tools you need to fix 90% of the problems that you'll ever have with these 850's and most other cars.
Old May 21, 2013 | 12:10 PM
  #22
slimflex2's Avatar
Originally Posted by one320fc
Ok I didnt really think about this much before. The 850 ran fine Friday no issues and Monday no start, just engine cranking would I get any DTCs from the computer?
did you check for the humming noise from the fuel pump when you turn on the ignition, my best bet will your fuel pump relay.
Old May 21, 2013 | 01:03 PM
  #23
one320fc's Avatar
Checked for codes none found. fuel pump seems to be working fine I even jumped the fuel pump relay and still wouldnt start only thing I havnt done is actually checked fuel pressure @ the rail. So im stuck with eiter a bad cam sensor or low fuel pressure
burtonsnowbird
Feb 11, 2006 05:02 PM
burtonsnowbird
Feb 7, 2006 01:07 AM
splash114
Jan 29, 2006 10:36 AM
PhilM
Jan 23, 2006 04:21 PM
