Still no brake lights after replacing switch!!!
Old May 16, 2010 | 04:15 PM
kollyn's Avatar
Default Still no brake lights after replacing switch!!!
I recently had my passenger side sway bar link replaced, and soon after I noticed that I had no brake lights! The only working light was the back window brake light. I replaced the fuse, checked bulbs, and was told by a friend to replace the brake light switch. I did so following detailed instructions...and still no brake lights!!
I have no idea if there is some correlation between the work I had done and lack of lights, or what the heck the problem is. This is not only hazardous, but f-ing frustrating!
If anyone has ANY ideas as to what the problem is or advice, PLEASE respond to this post.
-Irritated Volvonian
Old May 17, 2010 | 11:44 AM
mkc70's Avatar
Probably just coincidence. Meter the brake light plugs to ensure they are getting the pedal signal. Problem may be related to the bulb check circuit or fuse if you are only getting ground.
tekarra
Oct 1, 2013 01:27 AM
ChrisHuntze
Jul 7, 2012 01:52 AM
-JR
Aug 18, 2011 12:15 PM
sdat1333
May 15, 2010 10:51 AM
cioara
Apr 8, 2008 10:01 PM
