Straight 5 manual build
Old Dec 1, 2019 | 05:29 PM
woodsracer's Avatar
Default Straight 5 manual build
Hey guys, new to these forums and still new to Volvo. In terms or Swedish engineering, I have owned 3 SAABs over the years (2 prior to GM "influence") and have loved them, and have also had a 2012 S60 T6 which had a great motor but I disliked the auto trans and the chassis was sloppy (was stock and had 100k on it so not necessarily the fault of the car). I have since sold that, still have a SAAB 9-5 wagon but am looking to do a Volvo build. SAAB has frustrated me and the Volvo 5 cylinder turbos are unique and very cool in my book, so on to Volvo perhaps. I have drooled over the boxy Swedish style for a long time and it's time to do something - I am really into the 700/900 series look but like the 200 series, 850, and later stuff like the S90 as well, all in sedan and wagon versions but may prefer sedan for this. I'm lurking around reading as much as I can but there's a lot of info here and I am a bit overwhelmed. That said, here's what I'd like to do:
I'd like to build a turbo straight 5 to somewhere in the neighborhood of 350-400 whp with a manual 5 speed using Volvo parts (for the most part). Would it make the most sense to start with one of the 2.3 straight 5's like the B5234T? My neighbor has a non running '95 850 turbo I can swoop up for a few hundred bucks as a starting point if this is the right path. I've read from you guys the pistons are alright up to around 400 hp but you need rods? Can anyone point the way to some rod kits for these/similar motors so I can get an idea on investment? It's said that Volvo parts are very expensive (I assume these points are mostly regarding OEM), is this true for the older mid-90s models OEM and how about aftermarket? I needed an alternator for the S60 and OEM was around $1200 which I thought was completely insane. May be similar to Audi and Mercedes I don't know.
My intention is to swap a built motor into a RWD 700/900 or possibly 200 series, but if it's hard to find a nice donor car or options are limited, I'll get by with a FWD (ie. keep the 850 is that's the route I go). AWD is enticing but those systems are mostly safety oriented vs performance, right? Mainly FWD anyway? Not sure if AWD would make much difference with that much power, plus the rear end mods that would be necessary? Could someone expand on the models that one of the better suited turbo motors would fit in without major fabrication? I'm worried about engine/trans mount compatibility, I could weld mounting points but would like to avoid major fab if possible - are there kits for fitment like this? My main interest is doing the engine build itself - one of the major reasons for pursuing all this is to expand my engine building capabilities, I have done a lot of work in the past but never done anything bottom end. For the 700/900 and maybe 200 series is it easy to fit manual transmissions from other Volvo models? What manual transmissions works best for higher power output and what mods are needed other than clutch? What are the best handling (or easiest to get handling good) out of the 200, 700, 850, 900 series? I assume not the 200 but there seem to be a lot of good available parts.
So in a long winded way, my question for this crowd is really if you could do a 350 to 400 hp (maybe higher) build with a straight 5, manual trans, going into any of the available chassis, what would you do if budget and spare time is a definite consideration? What motor and manual trans, what mods, and what chassis would you choose?
Old Dec 2, 2019 | 12:38 PM
firebirdparts's Avatar
Well, a caveman can merge a T5 850 and a 5 speed 850. If you go that route, you'll succeed. It won't take all year. It's going to drive like a front wheel drive car with a lot of horsepower. That's the downside.
Old Dec 2, 2019 | 01:00 PM
woodsracer's Avatar
Which engine would be the best baseline to start with, what manual trans, and what RWD chassis would you choose? Is the B5234T my neighbor has for cheap a good basis to start the build from?
Old Dec 2, 2019 | 07:22 PM
time to swoop up your neighbor's 850 Turbo, then start looking on Craigslist for a 850 NA with a manual transmission (850Ts with manuals are rare but you may find a T5R that has a 5 speed (at a price of course). Plenty of write ups on the net for swapping the manual into the 850T (going the other way around requires using the 850Ts wiring harness) where the only trick is how to wire around the PNP switch on the auto's shifter. To get 350+ HP from a T5 requires a bigger turbo - stock is a TD04-15G but you can use a 16T or 18T or upgrade the impeller/rotor with the bigger turbo parts. From there you need an ECU tune, bigger injectors (ie white or greens), a bigger downpipe, bigger intercooler, stronger hoses and other boost management bits. Best thing to do is to 1) set a budget 2) shop for blueprint designs at a Volvo tuner store and see what it will take to get a stage 2 design going. Another car model to keep your eye out for is a C70 coupe - they also can be found with a manual transmission and high pressure turbo if you have a budget for the going price.
Old Dec 2, 2019 | 07:29 PM
woodsracer's Avatar
This would be a good route if I were to stick with FWD, not out of the question but would like to get a plan going to get all of what I want to see if that's feasible.
So I know I posted about a straight-5, but the 6 is cool too... What are the options to swap a built B6284T out of a twin turbo S80 into a 900 series? Would the manual trans like the M90 work? Not sure how the electronics would work, would the whole S80 wiring harness be needed for something like this?
Old Dec 3, 2019 | 04:55 PM
the FWDs are traverse mounted engines - where the 700/900s have a traditional design so there's no guarantee the engine/transmission will mount up and you'd certainly need to build your own mounts and layout for the plumbing. If you want to do something badass for a 900 series, why bother with a white block when you can buy a mounting kit for a small block chevy or ford. At any rate, you can google "Volvo 960 engine swap" and see some blogs/forum posts for what people have done. That will also offer some links to the mounting kits.
Old Dec 4, 2019 | 09:12 AM
I am utterly ignorant about rwd/5 cylinder combinations. So here's a start:
5-cyl Rwd Tranny? - Performance Modifications - Volvospeed Forums
I don't think anybody currently posted here has done anything like this. I hope I'm wrong.
A volvo 960 is sort of the car you are looking for. That its, they had a white block engine turned around driving the rear wheels. They were all automatics in the USA as these things seem to unfortunately go.
Night_Wolf
Jan 27, 2011 02:52 PM
gorillajin
Sep 22, 2009 01:23 AM
Saleen9090
Apr 7, 2009 10:18 PM
SecondToNone317
Feb 28, 2009 06:11 AM
Citizen_Insane
Dec 7, 2007 09:01 AM
