Strange change in boost pressure
Old Mar 22, 2011 | 05:13 PM
tboysen's Avatar
Default Strange change in boost pressure
I am getting an increase in boost when the AC kicks on. It causes the car to surge a little when at speed, not really a jerking, and not a rush of power, just a small noticeable sensation and the gauge will jump about 5 psi higher.
Any thoughts?
Old Mar 22, 2011 | 05:46 PM
MattyXXL's Avatar
Have you washed your engine lately?
Old Mar 22, 2011 | 07:25 PM
tboysen's Avatar
Nope (?)
Just happens when the AC is on and the compressor cycles. When the AC is off all is fine.
Old Mar 22, 2011 | 09:46 PM
MattyXXL's Avatar
just wondering because mine used to do that when I washed my engine and the turbo got wet...
What are the PSI changes? from what to what?
Does it only happen under hard acceleration or just cruising at lets say 60mph?
Old Mar 23, 2011 | 07:47 AM
tboysen's Avatar
I do not notice it under hard acceleration, mainly at cruising speed or a when at a constant speed. Only happens when the AC compressor cycles on. The change in psi is about 5lbs of needle movement. You can feel the car slightly surge and or decel. It is an odd feeling, especially in volume traffic on the highway...
Old Mar 24, 2011 | 07:56 AM
tboysen's Avatar
Still can't get this sorted.... ugh...
Maybe the AC compressor is going bad and dragging more?
Old Mar 25, 2011 | 02:15 PM
boxpin's Avatar
Next time you are going to race someone roll down the window and tell them to hold on a sec while you switch on the A/C.
(thats a joke btw)
Old Mar 25, 2011 | 02:39 PM
Henry10's Avatar
(thats a joke btw)
That's funny, LOL
Old Mar 25, 2011 | 06:55 PM
tboysen's Avatar
hahaha... Well it is hard to keep the tires in contact with the AC off... I will be the one speeding and slowing down here in the summer...
Meanwhile, the mechanic say bring it in. Not sure if this is a byproduct from all the work that has recently been done, or just an opening up due to the fact that all the work has been done.
act1292
Aug 25, 2012 09:20 PM
endneu913
Mar 28, 2010 11:41 PM
1Gray760T
Nov 11, 2009 10:56 AM
mygreenbomb
Feb 29, 2008 06:09 PM
blkwgnt5r
Mar 10, 2005 01:18 PM
