Strange electrical problem
Old Mar 9, 2006 | 01:24 PM
kazooclown's Avatar
Default Strange electrical problem
Hey Guys I have a weird problem and I need help on the path to diagnosis.
I bought a 96 850 wagon- and everything works except, there is no power to the heater/ac control/fan controls,
radio, or
power windows
I replaced the igntion switch but still no go-
Can you guys give me a path to go through to get to the bottom of this?
Thanks very much in advance.
Old Mar 9, 2006 | 05:02 PM
kazooclown's Avatar
Default RE: Strange electrical problem
bump
Old Mar 9, 2006 | 05:49 PM
BecomingMore's Avatar
I'm sure you have done this already but have you checked fuses? could even try relays, some times if one is bad it "could" interfer with other equipment. Wouldn't hurt to check anyways, also see if any wires have gone bad
Old Mar 9, 2006 | 08:50 PM
Make sure all the small wires at the positive terminal are good.
After checking all the fuses and relays.
Old Mar 9, 2006 | 09:13 PM
kazooclown's Avatar
all the fuses are cool- can you guys direct me how to check relays?
Old Mar 9, 2006 | 09:40 PM
Under the cover that you access the Fuse panel from is a bunch of relays. Check in there.
Also do you know of any other repairs that were done to the car before you got it?
Old Mar 9, 2006 | 09:53 PM
kazooclown's Avatar
ORIGINAL: tech
do I just use a test light?
on each side of the relay?
I'd really appreciate specifics here as I am a bit of an electrical moron
and yes I did the timing belt
she passed safey just have to stitch in new balljoints.
currently I have power jumper from the power antenae spot but I would like an oem solution.
Old Mar 9, 2006 | 10:02 PM
I don't have all the Info home but follow link for wiring Diagrams and that should help you.
http://www.volvotechinfo.com/WD123/
Old Mar 9, 2006 | 10:28 PM
kazooclown's Avatar
k i got the diagram could you shed some light on the procedure to test the relays?
Old Mar 9, 2006 | 10:44 PM
If you found the relay then you can look on the diagram and find out which connector should have power and test it with a test light. Make sure you have power going into it first. Then feel if the relay clicks.
You can also check a yellow plug with a purple pull on it under the dash. Make sure it is secured all the way. That is the Dash plug.
Old Mar 9, 2006 | 10:45 PM
kazooclown's Avatar
THX VERY MUCH!
Old Mar 9, 2006 | 10:46 PM
Let me know how it goes.
mathanas
Apr 19, 2023 03:22 PM
SmithSwede
Jan 18, 2011 09:35 AM
not-so-mechanical Phil
Aug 22, 2009 06:09 PM
Vincef
Dec 22, 2008 06:52 PM
ludeless
Nov 19, 2005 09:12 PM
