Struts/springs for 96 wagon turbo
Old Jun 16, 2008 | 11:44 AM
autoxray's Avatar
Default Struts/springs for 96 wagon turbo
I have a 96 wagon turbo car and I plan to keep this car for years. WhenI go camping, the rear sags some and I want to eliminate this. I do load the car and carry 4 bikes plus a Thule cargo box on top.
Looking to improve ride (sport feel) and handling. Looking at the Boge (loved them on my old Audi 90Q), Koni, Koni FSD, and the Bilstein TC. Also, looking at the front strut brace and the rear brace. Do you think these are also worth doing?
So what struts are good for my application? Don't really want to lower the car because I go to trail heads for camping. I do want to take out some body roll, and I do want to eliminate the rear sag when loaded.
All suggestions are greatly appreciated.
Ray
Old Jun 16, 2008 | 11:53 AM
info2x's Avatar
Default RE: Struts/springs for 96 wagon turbo
[align=left]
Get some new swaybars from IPD
Heavy load springs... they will raise the rear end when the car is unloaded though.
Sway bar will do more. I've heard the rear one doesn't do squat, you also loose the 3rd row seat if that's important to you. I've got a front one, it's nice.
[/align][align=left] [/align]
Old Jun 16, 2008 | 12:20 PM
autoxray's Avatar
How much does the car raise with the over loads?
Old Jun 16, 2008 | 12:32 PM
info2x's Avatar
couldn't tell you since I've got stock springs.
What tire pressures are you using when you are going to load the car fully
Old Jun 16, 2008 | 01:10 PM
autoxray's Avatar
I run the same as dry- bought some new goodyear assurance 205/55/16's and had them fill with nitrogen so the pressure would be stable. Can't remember the pressure, just bought a few months ago. Jusst got 5k on the tires and they are going in for rotation and check. They are H rated as I gave up on the speed part of my life.
Old Jun 16, 2008 | 02:20 PM
info2x's Avatar
OK I ask because Volvo has two tire pressure specifications, the higher pressure one is what is used for fuel econ and heavy loads such as 5 people and cargo.
Old Jun 16, 2008 | 02:30 PM
autoxray's Avatar
I will have to check when I get home tonight. My understanding is that they aired them to the max rating of 44 lbs as listed on the tire.
Old Jun 16, 2008 | 11:22 PM
autoxray's Avatar
Well I checked and they are at 35 PSI. Tires rated max at 44 PS!.
What do you know about my other questions on the struts?
Old Jun 17, 2008 | 07:56 AM
JimKW's Avatar
testing
I can NOT reply even by editing.
Koni Yellow Adjustable.
Old Jun 17, 2008 | 09:31 AM
autoxray's Avatar
Jim
Does that mean I should really get the Koni Yellow Adjustable?
Old Jun 17, 2008 | 10:37 AM
info2x's Avatar
The Koni Yellow Ajustables ones are good from what I hear. I'm on stock shocks. Bilstien TC and HD are also good from what I've heard
Old Jun 17, 2008 | 11:35 AM
JimKW's Avatar
I was trying to say Billstein Touring is a choice of many, but with you loading Koni's might be a better choice. This is just an opinion based on reading posts, not actual experience at all.
Old Jun 17, 2008 | 09:13 PM
Quick Brick's Avatar
Hey now,
I went with the Bilstein when I replaced everything last fall.
Firm ride but when I fill the back the ride is smoother
[sm=icon_cheers.gif]
Old Jun 17, 2008 | 10:40 PM
When I replaced the suspension lastfall I went with the OE Bilstein HDs.
I still have the stock springs and the ride is firm(which I dont mind)but when loaded up the ride is very smooth.
gilber33
Feb 25, 2011 06:56 AM
drin
Aug 31, 2010 11:46 PM
90240DLGA
Sep 11, 2009 07:32 PM
imhereftw
Sep 5, 2009 08:14 AM
david3707
Suspension
Feb 25, 2009 08:05 PM
