Suggestions on where to find a CHEAP engine
Old May 15, 2013 | 11:15 AM
Volvo850WithTheDiceInTheMirror's Avatar
Default Suggestions on where to find a CHEAP engine
I need to find a replacement engine for my '97 Volvo 850 non turbo. So far my cheapest option seems to be the local JunkYard, was wondering if anybody had any better ideas. If you know where I can a brand new engine for cheap
Old May 15, 2013 | 03:21 PM
ibified's Avatar
First off "brand new" and "cheap" arent gonna work together, especially with the word "volvo" in there. A junk yard is probably going to be your best bet. I'm guessing that a new complete engine from volvo would be around 5 grand.
Old May 15, 2013 | 04:39 PM
louiebay's Avatar
go to the JY with a compression tester. Make sure you grab everything around the engine as well even though you may not need it. It's easier to work on the engine while it's out of the car. When you find the engine with good compression and no leaks, order the T-belt, water pump and tensioners, PCV system, oil, hoses, coolant, exhaust gaskets, and filters. Get some carburetor cleaner and degreaser. Pressure wash your engine bay. Find a friend who has swapped out an engine before to give you a hand. Set aside 2 days to tinker with the car.
doing all this yourself would definitely save you at least $1000 in labor.
Old May 15, 2013 | 05:05 PM
Check out craigslist in your area (you don't say where you are) for a full car or a parts car.
Start searching for options:
Google
or
Google
or
Google
Three different links,
Old May 16, 2013 | 10:52 PM
trufflehogg's Avatar
Default new engine
I might can help you...call me at 919-740-4698...I have 2 brand new engines I bought from Volvo Penta...they tested them for marine use for 10 hours on a dyno....they are super clean...i took the head off one and didn't even get my hands dirty...bob
Old May 17, 2013 | 11:25 PM
Or you can just go hog wild and drop this in:
Race Engine For Sale « TKi Motorsport
m4gician
Feb 1, 2010 10:30 PM
schigara
Nov 25, 2009 09:15 AM
team
Nov 25, 2007 05:30 PM
stu_cole
Sep 21, 2007 06:22 PM
preese
Jun 6, 2007 09:18 PM
