Suspension Questions !!
Old Jun 11, 2011 | 07:56 PM
BigBear854R's Avatar
Default Suspension Questions !!
Two quick questions that I have not found an answer to online. I have a 1996 volvo 850R sedan. I am in the process of rebuilding the front suspension along with the rear. When it comes down to the shocks and struts I am not sure if the 850R has nivomat suspension ? I can't seem to find that anywhere. Is there any cheaper alternatives to the expensive stuff for the nivomats out there on the market ?
Thanks in advance !!
Old Jun 11, 2011 | 08:00 PM
I don't think the sedans have nivomat. You can get some good options from iPd and FCP.
Old Jun 11, 2011 | 08:14 PM
Is there a way to tell if i do by chance before i order the goods from IPD ?
Old Jun 11, 2011 | 09:00 PM
MattyXXL's Avatar
The 11th pic down in matt01's first post shows what the nivomat's look like
https://volvoforums.com/forum/volvo-...edition-40602/
Old Jun 12, 2011 | 09:22 AM
walter leever's Avatar
if your'e in the process of changing your suspension,go for coilovers,makes a huge difference(should be about the same price if you've got nivomats)
gr,walter
Old Jun 12, 2011 | 12:02 PM
Thanks for the help everyone. I did check my car against those pictures and looks like I do not have nivomats !! One last question when I turn off the car I get a buzzing noise around the drivers side of the dash and the battery light kicks on for a couple of seconds then goes off ? I replaced the micros-switch for the shift lock and that did not work so I am wondering if the solenoid is bad or could it be a combination of the ignition switch/solenoid. Any thoughts ?
Phil 850
Jul 25, 2012 10:01 PM
mcaanda
Sep 21, 2010 07:53 PM
960 rookie
Mar 29, 2009 07:33 PM
wetgloves
Mar 16, 2009 09:48 PM
