t5 96' misfire under heavy deceleration
Old Sep 13, 2023 | 07:02 AM
splifdrift's Avatar
Question t5 96' misfire under heavy deceleration
so im yet to do an overall service on my 1month volvo 850 t5 MT , beside some things to look around last owner changed belts and service it 2 years ago
car runs ok. under some heavy deceleration, like in 2nd flooring it and letting off the throttle at high rpm range , the car have a misfire or what it feels as ignition with an open exhaust valve, also on iddle when the engine is hot and has been used a bit, it misfire as "burps" , always the same one not random ones.
hoses looks ok, ive changed some vacum dryed ones just in case, and patch a whole in the intake one
i could not manage to read codes , I'm gonna build a led reader
what should i try first before opening the head?
what about the camshaft position sensor?
thinking to test compresion on the cyl's as an easy way to see how are the gaskets
Smky0069
Aug 26, 2020 11:51 AM
Andrew Fritz
May 9, 2020 08:28 AM
arlindlaci
Feb 19, 2020 12:56 PM
Jpriak
Jan 27, 2017 12:13 PM
sk799
Apr 9, 2009 06:14 PM
