tach not working
Old Apr 8, 2011 | 09:00 PM
Stripes's Avatar
Default tach not working
I have a 1995 850 n/a, and the tach doesn't like to work
some days (particularly warmer days), my gauge will work fine, others, not at all, and sometimes, the needle will bounce from actual RPM to 0 and somewhere in-between before dropping back down to 0
everything works fine, and the car runs great without the tach, but I would really like to be able to see my RPMs and be able to shift more smoothly. It seems to be a loose connection somewhere, but I have no idea where to start
The cluster is a Yazaki, and I haven't been able to get it to go into the test mode through the OBD I system
Old Apr 9, 2011 | 01:35 PM
MattyXXL's Avatar
That is a good sign of your ignition switch going... are yo u experiencing any other issues such as your lights not coming on or delayed seatbelt warning ding?
What happens when you jiggle the key when its not working?
Old Apr 9, 2011 | 06:00 PM
Stripes's Avatar
none of those problems
it decided to work this afternoon, so next time I go out, I'll try that.
Old Apr 10, 2011 | 07:07 PM
Stripes's Avatar
messing with the key did nothing
Old Apr 10, 2011 | 07:33 PM
Stripes's Avatar
I also can't pull any diagnostic codes for the cluster through port A7 on the OBD system
tried the 3-press test mode
nothing
tried the single-press code puller
nothing
Ilikemybike
Jan 8, 2015 01:53 PM
rspi
May 15, 2014 07:36 AM
97black850
Jun 17, 2013 03:36 PM
BigAdam
Oct 21, 2008 10:01 AM
