Tacho trouble
Old Apr 3, 2013 | 07:23 AM
skittso850R's Avatar
Default Tacho trouble
Hi, I have a volvo 850R 1996. I have a problem with the Tacho. When the has not running the tacho needle is sitting well below the 0 RPM on the gauge. When you start the engine it goes up and reads 0 RPM so it is about 700 RPM out. When you rev the motor the tacho goes up and down as it is supposed to ,just seems to be about 600-700 RPM out. Does anyone know how I fix this??? I think the person before me has repaired the speedo /Odometer nylon wheel at some stage as the plastic window has a small crack and the speedo reads fine. I am just wondering if they could have moved something when fixing that. If anyone can help that would be great. Thanks in advance.
Old Apr 3, 2013 | 08:46 AM
buckhr's Avatar
I am about to do the odometer repair and from what I understand, yes, (re)setting the tach/speedo is part of the repair. People have warned about being careful of this step.
Old Apr 3, 2013 | 02:21 PM
MattyXXL's Avatar
Your needle is off, you need to re seat the needle at the correct point
Old Apr 3, 2013 | 02:27 PM
Best to research the odometer gear replacement instructions. You can Google it and get them here, IPD, Volvospeed and Matthewsvolvosite to name a few.
It's likely someone was in there and put the needle back on in the wrong position.
Old Apr 4, 2013 | 03:17 AM
Thanks guys. I have next week end off and I think I will tackle it then. I'll let you know the outcome.
Old Apr 4, 2013 | 03:49 AM
Tip for the wise... don't try to squeeze the cluster out of the 1/2 removed/ raised dash, you will damage the dash pad. Remove the dash pad totally. They are fragril and will break and make noise forever.
DrAardvark
Nov 9, 2011 05:05 PM
bartman
Sep 2, 2008 01:46 PM
TBoone
Aug 8, 2006 12:52 AM
cpayette
Jun 21, 2004 07:22 PM
