Tail/Brake lights going out...
Old Mar 12, 2007 | 10:21 PM
RedTurbo850's Avatar
Default Tail/Brake lights going out...
So yesterday I was kind of messing around w/ my brake pedal, and I was pressing it w/ the ignition off.
However, when I started driving, my light was out. I drove a little further and the problem fixed itself. However, I was in traffic today, and I had to hold the brake for a very long time and the light went out again....
Anyone have a clue what the problem is?
Old Mar 12, 2007 | 10:42 PM
Default RE: Tail/Brake lights going out...
Maybe the switch needs adjusting.
Old Mar 12, 2007 | 10:46 PM
info2x's Avatar
You should be able to tap the pedal for the lights to activate. If they don't you need to adjust your switch.
This fall I discovered that I could stop my car without my brake lights ever activating. Luckily I didn't discover this by having someone plow into me.
[align=left] [/align]
Old Mar 12, 2007 | 11:05 PM
^The light activates if I give the brakes a little tap...
Seems that they'll go out if I hold the brake for a long time though...
Old Mar 14, 2007 | 11:45 AM
JPN's Avatar
JPN
Hi Jimmy,
Greetings from, well, Japan[8D].
If adjusting the switch doesn't solve the problem, try disconnecting the connector and cleaning it with electrical contact cleaner or WD-40. Then, connect & disconnect the SOB several times. Also, look for loose mountings.
I feel like I'm in a foreign country now. How depressing.
JPN
Old Mar 16, 2007 | 02:41 AM
It doesn't seem like a connection problem.
If I hold the brake for a long time (in traffic/waiting) the drivers side light will go out. However, once I begin driving again, it'll come back on. Sometimes it takes a little bit but if I drive it, it will come back.
I want to say it's an alternator problem, but that wouldn't explain why it's only 1 taillight....I think I just replaced the drivers side light too (In Oct/Nov)...
Old Mar 22, 2007 | 12:25 AM
This is annoying....
It wasn't working all day and it suddenly started working again. I don't think it's an alternater problem.
Sometimes, the brake lights will go on as I'm braking. So I'll have the dummy light on as I'm braking, and suddenly it'll go away... I have no clue what kind of problem this could be....
Old Mar 22, 2007 | 08:36 AM
Volgrrr's Avatar
I'd be checking for a loose or 'dry' connection in the taillight housing and also the thin metal filament that joins the various sections of the tail/brake light assembly for continuity.
Sometimes vibration will cause a connector or circuit wiring to momentarily 'open circuit' (the lamps wont illuminate no matter what you do)and then vibration can do the exact opposite - vibrate the loose connection back together (hey presto, the lamp works beautifully).
Good luck - I hope you find what is causing this irritating and potentially dangerous problem soon.
Old Mar 26, 2007 | 07:45 AM
JPN's Avatar
JPN
Hi Jimmy,
I'm sure you know this, but as the bulbs light up, the metals around them expand a bit. This may be causing temporary "disconnection", or open, between the cheesy looking back plate and the bulb.
Try taking the back plate (housing) off, visually inspect for hairline cracks/burn marks on the conductor paths. Then clean the conductor paths with electrical contact cleaner/WD-40, wipe off excess completely and see what happens. If it doesn't solve the problem, try wedging a thin piece of metal between the bulb tangs and the socket, making sure not to create a short circuit.
Try this and if it doesn't solve the problem, update us.
Keep an eye on the rear-view mirror until the problem is gone!
JPN
[IMG]local://upfiles/6892/794378AA612F40D3A7A599F4C5334D11.jpg[/IMG]
88740gle
Nov 13, 2015 08:13 AM
Anasanjo
May 19, 2015 09:43 PM
Mellott
Jun 13, 2011 11:41 PM
snowing
Mar 29, 2011 12:34 AM
buellfire
Jun 20, 2009 12:37 AM
