TD04HL-18T or TD04HL-19T (which would you get?)
Have you seen this http://forums.turbobricks.com/archiv...p/t-10961.html seems like good info.
How do you like the flow master exhaust? Went on their website and couldn't find a Volvo specific system, did you use the universal? what about the down pipe?
The exhaust sounds pretty good. I added a glass pack from Summit racing at the tail pipe too just to keep the sound down. I didnt want the wife complaining. It is tame though. I may get a second pack and replace the flowmaster just to see what sound diff it makes. I am still running the factory downpipe. When I get my final turbo I will get a downpipe to match. I may end up with the OBX system so I have not put to much into the exhaust since I might have to change it all. I am in Calif so I have to have a Cat in place. I did use the uinversal. If you look at the Forum photo gallery I have a segment that has a photo of it.
18T is a safer turbo. From what I've seen, people go with the 18T with stock internals. Doesn't build boost as fast as the 19T, therefore, less chance of bending a rod. The 19T at times has erratic boost spikes at low rpms, that's how it became known as the rod bender. 18T can boost around 18-22 psi, and the 19T I think can go above 25 psi, of course that's with supporting mods for both turbos. Each I would get a wideband, for the 19T you should get an EBC. Both would need larger injectors, and a custom tune, since you already have IPD, a remap.
dieselcruiserhead
07-17-2013 06:27 PM
jessica
07-06-2010 12:53 AM
