Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
What's The Differences Between Td04hl-15g And Td04hl-16t
Old Apr 29, 2010 | 03:41 AM
jessica's Avatar
Default What's The Differences Between Td04hl-15g And Td04hl-16t
What's are the differences between the TD04HL-15G (850 T5) turbo and the TD04HL-16T (S70 T5) turbo ?
i dont know much about volvo Models,
so I would be happy if you can elaborate your answer, and the differences between the two turbochargers.
thanks, jesse
Old May 12, 2010 | 11:37 PM
swiftjustice44's Avatar
post this question on turbobricks. There's a fair amount of folks there that actually like the Mitsu turbos.
Old May 22, 2010 | 09:11 PM
darksurfr's Avatar
The 15g has a smaller wheel and an older G style wheel which is a fraction of a bit heavier then the newer T wheel which spools quicker. The 16t housing also holds more boost to redline if need be. In a 3/S that turbo I believe can hold 15 psi to redline but that is a pair of those turbos and not one. Overall the 16t is a bit better.
Old May 27, 2010 | 05:48 AM
jedc53's Avatar
I bought a volvo TD04hl 6cm3 off Saab Kid,The 15g has a smaller wheel and an older G style wheel which is a fraction of a bit heavier then the newer T wheel which spools quicker.He said it'd bolt right up, and it looks like it will.They had the larger lucas injectors and a slightly different 15G compressor Vs. the 15T.
Old Jun 1, 2010 | 03:27 PM
backdrifters's Avatar
http://www.turbobricks.com/forums/sh....php?p=1105805
just scroll down until they stop gloating and you will find your answer, it basically came down to more peak flow
Old Jun 27, 2010 | 10:57 PM
boxpin's Avatar
15G puts a smile on your face, 16T buts a bigger smile on your face.
Old Jul 1, 2010 | 07:38 AM
danielhenry31's Avatar
The 15g has a small wheel and the wheel of an old style of G which is a fraction of a bit heavier, then the new wheels T rolls faster. The house also has more than 16 tons Redline boost if necessary. In 3 Turbo / S that I believe can have 15 psi to redline, but a pair of these turbos, not one. Overall 16 tons is much better.
Old Jul 6, 2010 | 12:53 AM
stephenmcsmith's Avatar
According to me, 15g or 16t will both work, just make sure you get a straight-flange 15g. No real point to putting the 15g on, you'll just loose performance to it. Stick with a 16t.
rspi
Mar 9, 2016 08:17 AM
Chrispy_T
Jun 9, 2013 12:35 AM
chax
Dec 21, 2011 05:00 PM
boxpin
Dec 15, 2009 03:43 PM
anubyss
Jan 1, 2006 06:29 PM
