Is there a way to get my antenna to go down (aftermarket stereo)?
Old Jan 27, 2008 | 05:30 PM
quarterdimenickel's Avatar
Default Is there a way to get my antenna to go down (aftermarket stereo)?
I really need to get all this salt off my car, so I'm going to head to an automatic car wash the next time the temperature gets above freezing. However, I'm afraid my already gimped antenna might not hold out too well. It was simple enough with the old volvo stereo, just hit the power button and the antenna went down, however there is no way to turn my current stereo off. Would I be able to just turn the car off?
Old Jan 27, 2008 | 05:37 PM
Default RE: Is there a way to get my antenna to go down (aftermarket stereo)?
Why can't you turn the stereo off?
You should be able to turn all of them off.
Old Jan 27, 2008 | 05:52 PM
green850's Avatar
you must not have your head unit hooked up right, check your remote wire i think it's solid blue
i've put in two head units in my 850, and my antenna goes up when my head unit gets power and down when it turns off
Old Jan 28, 2008 | 04:33 PM
It doesn't go down when I turn it off.
And I thought I was saving time by taking CC up on their offer of a free installation.
Old Jan 28, 2008 | 06:33 PM
They screwed up I would make them fix it.
Old Jan 29, 2008 | 08:24 AM
Psaboic's Avatar
Yes, someone definitely screwed up the wiring part of the installation. You should be able to turn the stereo off and have the antenna go down
Old Jan 29, 2008 | 08:40 AM
Systek's Avatar
Everyone is correct, unless, the power antenna itself is now broken(due to freezing weather).
Old Jan 29, 2008 | 01:38 PM
It tends to go up only a third of the way in freezing weather, compared to two-thirds normally (top has been broken since I bought the car).
Oh well, it's 42 degrees out, I might as well wash the car by hand.
rspi
Jan 2, 2013 09:37 PM
tboard24
Jun 25, 2009 08:43 PM
HelgaTheS80
Jan 9, 2007 01:54 AM
yellow95
Apr 12, 2006 02:37 AM
