Thermostat housing
Old Dec 14, 2007 | 03:11 PM
otlip's Avatar
Default Thermostat housing
Hello and thanks for the help,
I could not get the torx bolt out of the thermostat cover, wound up cracking the housing that goes into the block. Can someone give me an idea what I have to remove to take the main housing off of the block.
Thanks in advance
Richard
Old Dec 14, 2007 | 06:24 PM
Default RE: Thermostat housing
I believe you will need to remove the power steering pump and Alt.
Then I think you can get to it.
Old Dec 15, 2007 | 01:07 AM
JPN's Avatar
JPN
And you will need the following parts:
1. Housing
P/N: 1397909 (Volvo)
$66.50
2. Gasket (FCP Groton has miswritten it as "waterpump housing gasket", where as it is actually the T-stat housing gasket).
P/N: 1397574 (Elwis Royal)
$2.00
And in case you need the upper housing as well:
P/N: 3531478 (Scan-tech)
$20.00
They are at: http://www.fcpgroton.com/volvo850cooling.htm
Compare price & shipping deal with: http://www.eeuroparts.com/home.aspx
I hate those Torx screws because half the time they're guaranteed to strip.
JPN
Old Dec 15, 2007 | 08:43 AM
JimKW's Avatar
When I finally did get my torx screws out to replace the thermostat I put hex bolts back in to replace the damn tox screws. That is one thing I really hate about these car is the use of torx and in the case of the ABS module, an inverted torx.
Old Dec 15, 2007 | 09:42 AM
Psaboic's Avatar
Great tip/idea Jim/KW!
Old Aug 26, 2008 | 03:28 PM
outdoor7or24's Avatar
ORIGINAL: JimKW
How did you fit a hex bolt on the back side?
My 95 855t rear torx bolt is stripped, and now I need to figure out how to remove>>>>?????
I guess I need to pull out the fuel rail to get some room to use a screw extracter...
But it looks to tight to fit a hex bolt on the back side...
zbrink
Mar 6, 2019 04:55 AM
Bboble
Sep 19, 2018 06:29 PM
swederacer
May 25, 2009 10:09 AM
outdoor7or24
Sep 17, 2008 06:51 PM
JahMickey
Apr 23, 2008 02:29 PM
