Thermostat Housing problem.
Old Oct 4, 2009 | 09:26 PM
Chebucto's Avatar
Default Thermostat Housing problem.
Well I finally did my PCV system this weekend thats another story, but when I did this job I decided to change my thermostat and sensor since old man winter is coming. Problem I had is I got one housing bolt out, but the other would not budge. Its head is not stipped to no end. Any options?
Old Oct 4, 2009 | 09:32 PM
850tony's Avatar
frist try pounding a slightly over sized torx into it.
if that doesnt work, try a nut exractor (once of the things that cuts into the sides of the bolt head.
if that doesnt work, drill away just the head of the bolt (try not to drill off the bolt shaft at all). then take off the housing and vice grips the bolt out.
or..... put the other bolt in and leave it haha
Old Oct 4, 2009 | 10:20 PM
Try a good set of Visegrips!!!
Old Oct 4, 2009 | 10:46 PM
JPN's Avatar
JPN
Inspired!!!
Wait, if the screw is not stripped, you can spray PB Blaster, leave it for a half hour or so, then use 3/8" driver breaker bar.
If it IS stripped, may peace rest.....or:
- Try turning the housing CCW; this usually breaks the torque.
- With a small, sharp chisel & a hammer, aim at the corner of the screw and hit CCW.
- Replace the entire housing, meaning the bottom housing that fits the engine block (consider this as a last resort, and you'll need a square gasket to go with).
- Call your grandma (grandma usually knows everything).
As ultimate options, see attached. Consult EPA for local regulations.
JPN
Attached Thumbnails Thermostat Housing problem.-mk2_grenade_dod.jpg   Thermostat Housing problem.-nagasakibomb.jpg   Thermostat Housing problem.-plunger_250x410.jpg
Old Oct 5, 2009 | 08:42 AM
Psaboic's Avatar
When you do finally get it apart, replace those damn torx fasteners with some regular hex bolts so you can get it off easily the next time.
Old Oct 5, 2009 | 11:19 AM
fcpgroton's Avatar
Former Sponsor
PB Blaster is your friend.
Old Oct 6, 2009 | 09:30 PM
arzy's Avatar
I had the same problem, I used a screw driver (flat blade) and hit this with a hammer on the head, made a deep groove that I could the hit the screw driver at an angle and release it.
Old Oct 6, 2009 | 11:30 PM
850tony's Avatar
torx fasteners are a great thing. the thing people dont realize is even if it fits, and only has a little wiggle, it isnt the right size. torx are made to fit snugly, so that when you do need to tq down on them you have that stretch, but you still get it out. 90% of torx fastener head failures are due to the wrong size torx bit.
Old Oct 7, 2009 | 07:20 PM
VTBricked's Avatar
X2. I had the same problem and was not optimistic, but got the bolts out. There was just enough room to get the visegrips on the head and break the bolt free. PB will definitely help, too.
Bboble
Sep 19, 2018 06:29 PM
swederacer
May 25, 2009 10:09 AM
outdoor7or24
Sep 17, 2008 06:51 PM
otlip
Aug 26, 2008 03:28 PM
JahMickey
Apr 23, 2008 02:29 PM
