Ticking Engine
Ticking Engine
My engine has a sight tick to it. It seems to be there most of the time, but I noticed it will quiet down for a few seconds and start again sometimes. Is there a way to tell if it is the oil pick up o-rings or the lifters/cam followers? Is there a way to adjust the valve lash on these engines?
Thanks for the help!
switching to regular 10w30 Penzoil high mileage oil from synthetic resolved a similar issue on one of my friends car. Many people will disagree with this but I personally have switched back from synthetic oil to a Good brand regular oil based on the performance difference i noticed and many cases where the ticking noise from a engine with synthtic oil has completey gone with regular oil.
Update: I changed to Mobil 1 high mileage 10W40 and the noise is the same. Sometimes it is there and sometimes it goes away. I still need to give it some time to see if it will help slow down my rms leak. I plan on eventually changing the lifters and the oil sump o-rings, probably the o rings first since it is easier.
