Timing Belt
Old Apr 23, 2009 | 10:39 PM
HTRD2B's Avatar
Exclamation Timing Belt
I have a 1993 850 with a 5 speed. Last week I was driving around and the timing belt broke. Took it to the dealership and was told I bent several valves and did a fair amount of damage to the underside of the head. How much work would it be to replace the entire head? If it isn't to bad where could I find a head for relatively cheap and a head gasket etc. also is there any head I can put on to increase performance?
Old Apr 23, 2009 | 11:58 PM
Arsenal6's Avatar
I suppose u can try aftermarket or a salvage yard?
Old Apr 24, 2009 | 06:54 AM
JimKW's Avatar
If you get a relacement head make sure you get the combination of head and cam cover. They are milled out of one piece of metal and I have heard of people having problems when the try and use the head from one car and the cam cover from another. You may be better off just replacing the whole engine if you did quite a bit of damage.
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
