tips for replacing timing belt?
Old Mar 7, 2006 | 11:29 PM
spettinger's Avatar
Default tips for replacing timing belt?
hello all.
i am really kicking myself for not printing out the full description of a timing belt replacement on alldata when i had access to it. can anyone explain what timing marks i am looking for to tdc the engine before i take it all apart?? i would really like to get started on it right away! thanks!
Old Mar 7, 2006 | 11:35 PM
Default RE: tips for replacing timing belt?
Look on the Cams you will see a line on each cam. Then on the top timing cover you will see cuts that the lines will match up with. There is a mark on the Crank. Usually very hard to see unless you look just right.
After you get the belt back on MAKE SURE YOU CRANK IT OVER BY HAND WITH A RATCHET TWICE BEFORE STARTING IT.
S373N
Mar 9, 2014 11:23 PM
russellsv40
Jun 2, 2011 12:02 PM
mountain lion
Mar 6, 2011 03:44 AM
TrouperL
Oct 20, 2010 08:01 PM
jollygoodgold
Jul 16, 2007 12:06 PM
