Tire pressure
Old Oct 16, 2006 | 02:03 PM
Dads850's Avatar
Default Tire pressure
Quick question: I'm running a set of Potenza G009's and went to check the air pressure yesterday before the long drive home - they had 30/31 pounds so I set the air thing at the gas station to 36lbs and started pumping. When I was pumping the tires up, I checked out the sidewall and saw that the tire's max pressure is 44lbs. Now, I've always had regular all-seasons on my cars, never run performance tires so I wasn't sure what to do and put in 38lbs. Question is should I run 44lbs? I'm going to be switching over to my Nokian's soon anyway, so this is more for future reference.
Old Oct 16, 2006 | 02:11 PM
S70driver's Avatar
Default RE: Tire pressure
I would say run something in between like 40 pounds.
Old Oct 16, 2006 | 03:28 PM
info2x's Avatar
I'd run what the manual says to run at.
Old Oct 16, 2006 | 03:31 PM
billofdurham's Avatar
Why would you want 44 lbs? The sidewall marking is a warning by the tyre maker not to exceed that pressure. Depending on tyre size and use (eg driver only/fully laden; normal/high speed) tyre pressures for the 850 saloon range from 32 lbs to 38lbs front and 29 lbs to 41 rear.
Old Oct 16, 2006 | 04:12 PM
xjflexer's Avatar
Yeah, that PSI marked on the side of the tire is just there to let you know that is the absolute maximum pressure that the tire should be filled with.
With that said, only inflate the tires to what is specified int eh owners manual or on the decal on the body of the car.
Old Oct 16, 2006 | 09:04 PM
I would run them at 36PSI that is what I always set the Cust. tires to.
Old Oct 17, 2006 | 02:29 PM
code33's Avatar
Keep in mind that the manufacturer's suggested PSI is the cold tire pressure. Make adjustments accordingly if the vehicle has been driven.
http://www.tirerack.com/tires/tirete...jsp?techid=147
I normally run 2psi higher than the min.
Old Oct 17, 2006 | 05:20 PM
B1mmer's Avatar
I was getting pretty poor tire wear on my 850. I realized pretty quickly that I was running too low pressures all around (I was killing the outside edge, even with camber bolts). After moving it up to the 36F 41R that was an alternative suggestion beneath the gas filler lid, the ride improved tremendously and the tire wear is much better. Being a racer, I should have known that 31 psi up front was too low for a 3400# car [:'(] - AB
Old Oct 18, 2006 | 07:09 PM
code33's Avatar
Just curious...
What type of racing and in which category do you compete with the Volvo?
ORIGINAL: B1mmer
Old Oct 23, 2006 | 01:21 PM
B1mmer's Avatar
No racing in a Volvo, I do currently autocross a Mazda RX-8 in the SCCA. You could run any Volvo in autocross, it's just a function of how competitive you want to be. Here is a link to results from 2006 Nationals and a couple of other 2006 events. Scroll down to B-Stock, I'm Aaron Buckley. It's basically precision driving. It's a lot of fun and a big waste of money - AB
SCCA Solo Nationals 2006
SCCA Fort Myers Tour 2006
SCCA Walnut Ridge ProSolo 2006
- AB
Old Oct 23, 2006 | 04:16 PM
code33's Avatar
Nice job... Thanks for sharing the results.
Old Mar 23, 2010 | 04:15 PM
soulman62's Avatar
Default tyre pressure
can any one tell me the corect tyre pressure for the volvo 850 t5 turbo estate on alloys
hope some one can help thanks
Old Mar 23, 2010 | 05:24 PM
JimKW's Avatar
Did you read this thread? It's a four year old thread that tells you exactly what you are asking. Run them at 36 psi. We all have alloys on out cars.
heyitsomid
Oct 11, 2008 06:46 AM
HummerGuy
Oct 10, 2008 08:02 AM
kcw12
Jun 10, 2008 08:48 PM
daisydaisy
Jan 26, 2006 11:52 PM
