Upgrading question
Old Mar 23, 2008 | 10:59 AM
joshconstipate's Avatar
Default Upgrading question
So, I have a regular 850 and Im very new to cars in general but Id like im learning and would like to know what should I add to get more power. Well, what I should ask is where should I start upgrading at? I dont have a turbo, is that a problem, would it have been easier if i had gotten one? thanks
Old Mar 23, 2008 | 01:15 PM
quarterdimenickel's Avatar
Default RE: Upgrading question
Don't bother trying to increase the power on an N/A 850. It won't be worth the cost.
Yes, an 850R or T5 would be a lot easier to get extra power from.
Old Mar 24, 2008 | 08:33 AM
Psaboic's Avatar
There is nothing wrong with an N/A 850. Yes a turbo model would have been easier to upgrade, but there are items for regular 850's also. Check out www.ipdusa.com. IPD is one of the premier Volvo parts and upgrade sites.
Old Mar 24, 2008 | 08:54 AM
S70driver's Avatar
You have an N/A. Meaning you have around 168 Hp or so. Also it means there is limited performance parts available to you in the aftermarket world. Also with the parts avaiable you wouldn't make much Hp to make a difference.
Sell your N/A and a buy a turbo model.
If your thinking of turboing your N/A the answer is yes you can but the true answer is again sell your N/A and buy a turbo model. Some items you would need to turbo your N/A would be but not limited to...
1. Turbo
2. Intercooler
3. Intercooler hardpipes
4. Couplers
5. T-bolt clamps
6. Downpipe
7. Catback system
8. Vaccum lines
9. Oil and or water lines
10. Major ECU tuning (Not just a regular ECU tune, I am talking dyno tuning)
11. Etc...
To do this right your looking at at least $3k-$8k in parts plus labor charges as well.
Sell your N/A and buy a turbo model. There are more parts in the aftermarker world for turboed models and you will see more gains with these parts in a turbo model.
ORIGINAL: Psaboic
Yes there are N/A parts out there but they are truly not worth it because you wont gain much power if any power.
1. Catback system, you may gain 5-10 Hp max.
2. Custom intake, you may gain 2-5 Hp max.
3. You can get an ECU tune and possibly gain 20 Hp max, but don't bet on it.
4. QBM Cam Timing Tool, don't use this unless you know about cam timing.
So even with these parts your just getting to about 200 Hp if you make it to there. With a turbo model your at least starting close to 200 Hp if not over 200 Hp. And with the parts available you can get very nice numbers. Here is a short list of aftermarket parts for turbo models.
1. Turbo upgrade
2. Downpipe upgrade
3. Catback upgrade
4. N/A cam upgrade (Yes the N/A cams is an upgrade to the turbo models)
5. Better ECU upgrades that will make more power then an N/A ECU upgrade.
6. Intercooler upgrade (FMIC's included, has to be custom made.)
7. Silicone vaccum line upgrade
8. Silicone turbo hoses upgrade
9. Intake upgrade (Short ram, BMC CDA, and then you can custom make intakes)
Old Mar 24, 2008 | 09:47 AM
JimKW's Avatar
+1 for what s70driver said.
Old Mar 24, 2008 | 11:50 AM
JPN's Avatar
JPN
Or you can give a thought on this inspiring extreme.
JPN
[IMG]local://upfiles/6892/D46C4A9E12F44E5DB5A60122E1C54653.jpg[/IMG]
summit
Apr 24, 2009 10:03 PM
flamejet
Intake, Headers and Exhaust
16
Apr 12, 2008 02:50 PM
pvolvoman
Jun 26, 2006 01:38 PM
RonJeffries
Jan 8, 2006 12:58 AM
xmoke
Oct 17, 2005 02:31 AM
