TRACS and ABS light on
Old Jan 18, 2011 | 02:48 PM
allisone51's Avatar
Default TRACS and ABS light on
I've been told this means the rear wheel sensor needs replacing - expensive part. I live in snow country so not gonna get away without it...especially this winter!
Question is - are used parts okay for this piece of equipment?
Any good parts recommendation resources? I live in Southern Vermont.
Thanks!
p.s. 95 GLT 850 automatic - 168,000 miles or so.
Old Jan 18, 2011 | 03:28 PM
Henry10's Avatar
Sensors get gunked up and need cleaning. My lights were on too, read a bunch of codes, but after researching it here, cleaned them, erased codes and things were good. I still get an intermittent light, but I think I need to re-do the job on the front ones again.
This is not exactly what you were asking about, but I think cleaning them first is the right approach.
Old Jan 18, 2011 | 03:54 PM
vpatrol's Avatar
If you haven't done so already, I would have the codes pulled so you can definately isolate the problem. The light alone won't tell you its the rear sensor.
Old Jan 19, 2011 | 01:45 PM
brianb's Avatar
I was having a weird issue where my ABS and traction control would kick on for no reason at all. I cleaned the sensors and found the front/driver's side one to be totally gunked up as well as some gunk on the ABS ring. Cleaning it up and that did the trick.
Old Jan 19, 2011 | 01:51 PM
Henry10's Avatar
ABS Module soldered pins seems to be the problem on 1996 and later. 94-95 evidently -- it is the sensor cleaning that helps.
shoter_hellas
Nov 27, 2011 11:06 PM
DJ850R
Apr 30, 2008 08:13 PM
paulh
Jan 30, 2008 08:22 PM
jack2403
Jan 4, 2007 08:43 PM
vwown3d
Aug 20, 2005 03:01 PM
