Tracs Button not working...
Old Nov 21, 2010 | 09:14 PM
91shelby's Avatar
Default Tracs Button not working...
Tracs button not working on my 95 850 turbo, when i press it the light on the button comes on but the arrow does not come on on the panel though like it should.... any ideas
Old Nov 21, 2010 | 11:03 PM
Which arrow?
There should not be an arrow on when tracs is on or off.
Old Nov 21, 2010 | 11:17 PM
91shelby's Avatar
really? on my moms 96 850 when you pushed the tracs button the arrow came on...
the arrow to the right of the LCD panel
Old Nov 22, 2010 | 07:12 PM
The arrow only comes on when lower than drive or the winter button is pushed.
Old Nov 22, 2010 | 09:45 PM
Henry10's Avatar
When the TRACS button is pressed, Traction Control is turned off, and the light "TRACS" on the instrument panel is lighted. If you can't see this light with Key-on / Engine-Off, the bulb might be burnt.
Traction Control works for low speed, 30 mph or less I think.
Old Nov 24, 2010 | 04:38 PM
91shelby's Avatar
ah ok, well i when i start the car i see the tracs light come on for a second but the button does nothing, what would cause it not to work? ..
Old Nov 24, 2010 | 07:50 PM
An issue with the ABS module will cause it to stop working.
Old Nov 24, 2010 | 08:17 PM
91shelby's Avatar
hmmm, the obd keeps throwing rear wheel speed sensor codes ...
Old Nov 24, 2010 | 08:28 PM
I have seen a few go bad. But starting to see the 94-95 modules go bad as well.
schmuecker
May 19, 2011 06:45 PM
volvolove
Oct 2, 2009 09:38 AM
volvo22t6
Mar 7, 2008 09:55 PM
paulh
Jan 30, 2008 08:22 PM
